Thread: A6 2.7T Tuning
  1. A6 2.7T Tuning
    Mar 2010
    Gloucester
    I'm posting for a friend who has a V plate 2.7T, he's had it for a while and is now thinking of tuning it for fast road use.
    He's not wanting to go the top, just a exhaust and a map/chip for now.
    The question is what exhaust, can he loose all the cats (retaining the oe main cats for mot time), or are the pre cat too hard to get too? Whats the best way to go on the mapping, will he better with a live mapping, will a pre made one have the same result? i.e would it be worth the extra money?
    Any advice will be much appreciated
    Ad.
  2. Re: A6 2.7T Tuning
    Mar 2010
    Gloucester
    As you can see, i'm new to the forum, i've got a feeling i may have put this in the wrong section. If i have, would a Mod please help by moving it to the appropriate area
    Ad.
  3. Re: A6 2.7T Tuning
    Jan 2011
    Gloucestershire
    In the wrong forum, but here's your answer!
    The pre-cats can be removed and will help spool up the turbos even earlier. You need to keep the main cats in place for the MOT, but these can be replaced with sports cats (either 100 or 200 cell).
    Unless you plan on going above 350bhp you will be ok with a generic map.
    The main problem with these engines is that they suffer from a number of common problems which don't bring on the engine management light - they are;
    1) failing MAFs
    2) split DV's
    3) Boost leaks
    4) Failed lambda probes
    You will be better off getting it to a specialist who knows these cars to get it running corrctly before mapping.
    You can try Dan at TRD on 01453 766739.
    Hope that helps.
  1. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  2. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  3. At home on all roads and tracks - Audi A6 allroad quattro
  4. New Audi A6 Avant Range Update
    Last Post: 20-01-2005, 10:34 PM
  5. The new Audi A6 Avant
