Thread: abs ecu woes
  1. abs ecu woes
    May 2007
    Hi all
    First post on here....
    The ABS ECU unit on my 99 Passat 1.8T exhibited the usual symptoms of the flashing ABS, and brake warning light (becoming more frequent over time) with the fault code '01203' 'Electrical connection between ABS ans instrument cluster 03 10 - no signal- intermittent'
    My mate attempted to fix it by soldering the loose wire inside the unit
    (being the 'nothing to lose' option) but upon refitting it there is a
    problem, his vag com now refuses to connect to the main ecu or the abs ecu (It connected perfectly well before) and the message 'cannot communicate' comes up
    Before I get a 'proper' refurb carried out on the unit, can anyone advise
    why a bodge of the abs ecu fix might cause the subsequent lack of communication with all the functions of the car?
    Everything on the car works as it did before.
    He tried the vag com on his audi straight after and it was fine, so there
    is no problem with that
    thanks.
    Apr 2007
    Cumbria.
    Hello and welcolme.
    Something to do with the 2" wide soldering iron your mate used. Just a thought.
    It was broken BEFORE i touched it honest!
  3. Re: abs ecu woes
    Mar 2007
    hi there
    i have the same fault - did you ever get this resolved?
    Scott
    Quote Originally Posted by no.10 View Post
    Hi all
    thanks.
  4. Re: abs ecu woes
    May 2007
    I sent the abs control unit off to one of the well known refurbishers (not sure if I can name them on here?) and they said it was not possible to repair it.
    They sent me another (later apparently) unit with the pump attached and everything has been fine since the fitting of it. No lights appeared when the ignition was turned on so it didn't even require connecting up to vagcom again to clear the fault codes.
  5. Re: abs ecu woes
    Mar 2007
    I have bought a used pump and ECU with matching part numbers from a breaker but the lights are still on after fitting it - does it need to be coded to my car?
    Scott
  1. Climatronic woes
    By SW TDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2007, 10:48 AM
  2. Alarm woes!
    By quattro2000 in forum Audi A3 - Archive Topics
    Last Post: 26-03-2007, 10:25 PM
  3. Thermostat Woes
    By ben21 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-01-2007, 08:35 PM
  4. Start Up Woes
    By fugly in forum Audi A4 - Archive Topics
    Last Post: 02-01-2007, 09:50 PM
  5. Alarm Woes
    By Rado in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-12-2006, 07:35 PM
