Thread: Smokey and lumpy on morning start
  1. Smokey and lumpy on morning start
    Ireland
    Hi all, 2 issues to hopefully find the answer to on the wifes new 04 AWX Passat...
    1. is lumpy and a bit smokey on the first start up in the morning this clears itself after it warms up a little
    2. Engine seems a little droney at low revs(low speed), Ive checked the air filter and hoses etc as i had a similar prob on a 97 A4 where the air filter was not sealing correctly
    thanks in advance
    damien
  2. Re: Smokey and lumpy on morning start
    Mar 2009
    1. Possibly one or more glowplugs faulty/burnt out
    2. This is a common complaint usually related to the exhaust.
    Have you recently got the car or has the noise just started?
    Regarding the drone, I've got used to it and just live with it but if you do a search you'll find numerous threads.
    I came in to this world with nothing and I've still got most of it left.
  3. Re: Smokey and lumpy on morning start
    Jul 2008
    1, Could be the glow plugs as macquatic suggested. Also look at the MAF/AMM sensor and coolant temperature sensor, as if these are out, it could result in lumpy idling when cold.
    2, Have a look at your alternator belt and pulley. Take the alternator belt off and wedge a piece of wood inside the alternator fan blade within the casing. Now turn the wheel in both directions. If it doesnt turn in either, its shot. Also, have a look at your tensioner as these are prone to fail too. I had a low rev drone and this was the problem.
  4. Re: Smokey and lumpy on morning start
    May 2008
    defo glowplugs mine was the same it had 4 dead plugs and it still started first time in the morning th loads of smoke now its fine
  5. Re: Smokey and lumpy on morning start
    Ireland
    Thanks lads, looks like ill be replacing some glow plugs so, with regards to the drone its been there since we have the car, doesn't effect the performance as far as i can see....
    Thanks again
  1. Crasher! Help!
    By billybunter in forum Golf MK2 - 1984 - 1992
    Last Post: 11-06-2009, 07:59 PM
  2. Bora 115 TDi - Lumpy and Smokey start up when cold
    By BorisDBora in forum Bora - 1998 - 2005
    Last Post: 04-08-2008, 11:29 AM
  3. Lumpy Smokey and Smelly !!
    By acguildford in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2007, 08:52 PM
