Thread: Golf 1.4 mark 5- fan problem & exhaust light
  1. Golf 1.4 mark 5- fan problem & exhaust light
    Mar 2010
    Wakefield
    Hi - I'm having trouble with the exhaust emissions light coming on intermittently (not flashing) and also with the big fan coming on at top speed (the small fan remains off) and pulsing on and off intermittently. I took it to a small garage and had the computer diagnostics run on it, and only a fault with the fan system was highlighted - nothing on the exhaust system. The man told me to identify the problem fan and have it replaced. But presumably this wouldn't have anything to do with the exhaust light coming on?
  2. Re: Golf 1.4 mark 5- fan problem & exhaust light
    132 Post(s)
    1980 Post(s)
    I think you need it code rereading properly, there must be a reason for the emissions light coming on. Also, make sure you get a fault code print out, the fault code numbers are vital for us to help you.
    I suspect it will be a faulty coolant temperature sender.
  3. Re: Golf 1.4 mark 5- fan problem & exhaust light
    Apr 2007
    See my thread about a very similar problem. I've still not got to the bootom of it yet having changed one of the fan sensors.
  4. Re: Golf 1.4 mark 5- fan problem & exhaust light
    May 2007
    17 Post(s)
    There is a tech bulletin issued by VW relating to this problem. The emissions light comes on due to.....dirt ingress into the No.2 cooling fan (the small fan if I remember right). The cure is to replace the fan.
    I'm not saying that is what's wrong with your car. Someone who works in the VW dealership would have to check your chassis number to see if the bulletin relates to your vehicle. Perhaps if you post your chassis number someone on the forum could check it for you.
    Regards - Jim.
  5. Re: Golf 1.4 mark 5- fan problem & exhaust light
    Mar 2010
    Wakefield
    Thanks folks.
    Flash2, I will get that chassis number up as soon as poss... hopefully someone can confirm as you suggest!
  1. Golf 1.4 GT TSI Boost Problem
    By scov1984 in forum Golf MK5 - 2004 - 2009
    Last Post: 22-01-2017, 05:59 PM
  2. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  3. Exhaust mission warning light.
    By ronnyb in forum Golf MK5 - 2004 - 2009
    Last Post: 15-03-2010, 11:33 AM
  4. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
