Thread: Engine Juddering / Too Hot
Results 11 to 20 of 31
  1. #11
    Oct 2005
    Lutterworth
    Quote Originally Posted by shahabudeen View Post
    nah the temperature stays on 90. i thought thats to do with the coolant.
    Yes, the gauge stays on 90 but the actual engine temperature will be different as the gauge does not truly read the engine temperature.
    As you are expressing a concern over the engine temperature and have the required tool, why not find out what the actual temp is ?
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Nov 2006
    This is what i got from the Vagcom. I dont know much to use it properly, i couldnt find how to measure the engine temperatute.
    can anyone help
    I had the same problem as you did recently and that (cat) was also glowing red.I also got new spark plugs but they weren't the problem . Replace the ignition coils since the cylinder misfired you don't have to replace all of them but the bad ones (might be just one). It was hard to find the bad coil, had to move them a bit while the engine was on to find it.
    Oct 2005
    Lutterworth
    Quote Originally Posted by shabs View Post
    Hi. The reason it does not make sense is that there is no Label file loaded, see where is says Lable File : none ?
    The label file is where the text comes from for the measuring blocks.
    The easiest thing for you to do is to download the latest zipped label files from Ross tech :
    http://www.ross-tech.com/vag-com/dow...els.060728.zip
    Extract them and copy them all into where you have VAGCOM installed, probably :
    C:\Program Files\VAG-COM\Labels
    Overwrite any if the message comes up.
    Now try your VAGCOM again and it should load a label file applicable to your ECU part number. If it does then the measuring blocks should have nice text labels on them and you can step through them from 001 and see where the engine temp is displayed.
    Rgds
    Passat 1.8SE 1998
    Nov 2006
    Thanks for all your help lads. ive downloded the labels pack - cheers lex.
    i think i might have to change the coil pack. initially when the car started juddering the cylinder 2 and 4 coil packs popped up. are they the ones which have failed. vag com diagnosed it as cylinder 2 misfire and random misfire. how do i check them since the fault has now cleared and how much do they cost.
    where can i buy them from and is it a DIY job.
    help appreciated
    cheers
    Oct 2005
    Lutterworth
    If all is well at the moment why not swap them over with a coilpack that has not displayed a failure and drive the car and see what happens.
    Give GSF a call for prices.
    www.gsfcarparts.com
    After downloading the label file, do you see text on the measuring blocks ?
    Passat 1.8SE 1998
    Nov 2006
    Thanks for your quick reply lex. do you have any instructions to swap over the coil pack, is it easy to do. yeh the label file you told me to download had 666 files as supposed to 141 there was already in the folder. hopefully later on i will measure the reading blocks
    thanks mate
    Oct 2005
    Lutterworth
    Off the top of my head....
    Undo the two screws holding the ignition harness to the top of the head.
    Disconnect all 4 coil packs.
    With a pen mark them 1 to 4 from the front
    They just pop out, as you know :-)
    Swap 1 with 2 and 3 with 4
    Fasten it all up and test.
    Passat 1.8SE 1998
    Nov 2006
    hi lex, im still not getting any label files.
    Oct 2005
    Lutterworth
    No, there is not a label the matches your ECU p/n 8E0 909 557.
    What is your engine code ? Is it ALT ?
    If you just step thro the measuring blocks you will find what can only be the engine temp.
    Passat 1.8SE 1998
  1. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  2. juddering or missfire
    By grumpyob in forum 80 - 90
    Last Post: 17-02-2008, 05:38 PM
  3. mk3 golf gti juddering
    By chelski205 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-06-2007, 11:42 AM
  4. Juddering S4
    By Lenny75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2007, 06:28 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
