Thread: Engine Juddering / Too Hot
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Engine Juddering / Too Hot
    Apr 2007
    Experts - please help
    just had car serviced; replaced air,oil and fuel filters. fitted new spark plugs and coolant temperature sensor.
    recently when i was driving the car started juddering as if it was running out of fuel. the car would just not move. i opened up the bonnet and it was extremelyhot. the bit behind the MAF sensor, i think its the lambda unit was glowing red (belive its the cat) and the engine was juddering. 2 of the spark plug housing had popped out.
    any ideas what it could be. engine management light was flashing, so hooked it up to VAG com
    it found the following faults
    - Random / multiple cylinder Misfire detected : p0300
    -cylinder 2 misfires p0302
    -sporadic 001-upper limit exceeded
    mass air flow meter signal too low
    just had MAF replaced recently as well
    Help Appreciated
    Cheeers
    _______________________________________
    Audi A4 2001 2.0 SE
    Oct 2005
    Lutterworth
    Quote Originally Posted by shahabudeen View Post
    Surely that would cause the juddering ??
    As you have a vagcom, log the map actual and requested blocks while driving, to confirm that the MAF is working correctly.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Dec 2006
    Coil pack has failed and has caused it to throw a wobbly..
    Thats my guess mate..
    Check the coils and report back..
    its pretty common (apart from the red glow..)
    RicKT
    Apr 2007
    Hi rick,
    by coils do you mean the spark plug housings. what should i look for. i did change the spark plugs, just in case the shop sold me the wrong ones for the car.
    cheers
    Audi A4 2001 2.0 SE
    Apr 2007
    Quote Originally Posted by Lex Luthor View Post
    ive never done this b4, can you guide us thru it mate
    many thanks
    Audi A4 2001 2.0 SE
    Oct 2005
    Lutterworth
    It will probably be measuring block 003.
    If not can you post the part number of the ecu as read from vagcom. When you open the controller it is listed in the "VAG Number" box.
    Mearsuring blocks and logging is here :
    http://www.ross-tech.com/vag-com/tour/m-blocks.html
    Passat 1.8SE 1998
  7. Engine gets Hot
    Apr 2007
    Hi All,
    Ive replaced the 4 spark plugs with iridium bosch ones. the juddering has now stopped. but for some reason the engine gets extremely hot after even a short journey. the air filter is too hot to touch. im a bit sceptical to take it on a long drive just incase the same juddering re-occurs.
    can anyone help, vag cam says no faults found.
    cheers (RickT)
    Audi A4 2001 2.0 SE
    Dec 2006
    when you say hot... how hot?? does the needle more above 90'c?? it should never move above unless something is wrong..
    RickT
    Oct 2005
    Lutterworth
    Can anyone help, vag cam says no faults found.
    With your VAGCOM you can read the actual engine temperature, not the sanitised version as displayed on the gauge.
    What is it?
    Passat 1.8SE 1998
    Apr 2007
    nah the temperature stays on 90. i thought thats to do with the coolant.
    Audi A4 2001 2.0 SE
  1. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  2. juddering or missfire
    By grumpyob in forum 80 - 90
    Last Post: 17-02-2008, 05:38 PM
  3. mk3 golf gti juddering
    By chelski205 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-06-2007, 11:42 AM
  4. Juddering S4
    By Lenny75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2007, 06:28 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
