Thread: Dual Mass Flywheel Replacement
  1. Question Dual Mass Flywheel Replacement
    Apr 2007
    I have a 2000 Alhambra TDI (115bhp). It has been used to tow a caravan from time to time. It now has 94500 miles on the clock and the clutch is causing problems, in short it will not lift to change gear. If the flywheel requires to be replaced and I am told it should be replaced if the clutch needs replaced, is there any reason why I should not replace it with a conventional assembly?
    Any comments would be welcome
    Thanks in advance
    Ivan
  2. Re: Dual Mass Flywheel Replacement
    Mines went quite recently and they quoted me £1,600 for both. Couldn't get a conversion kit for my 130bhp but you may be lucky. Sourced parts from eurocarparts and the same garage replaced for £750.00.
  3. Re: Dual Mass Flywheel Replacement
    Feb 2010
    larne
    hello mate im a caravaner myself...ive just replaced my dual mass flywheel and clutch and thrust bearing im not a mechanic but i am competent, please note to do this job you WILL need a jig to hold the flywheel so you can undo the bolts, i had access to a welder and steel bar so i could make a jig, i would have been beat without it.....i purchased the dual mass flywheel and clutch and hydrualic realise bearing from EUROCARPARTS THE COST FOR THE COMPLETE KIT WAS £380....£30 of this was for the hydraulic bearing it had to be bought seperate, i now have a smooth gear change and shudder free clutch i only needed help to reinstall the gearbox its a pig....worth the hassle saved myself £400 in garage labour costs.... one more thing to watch for is the clutch pipe over the top of the bell housing remove this before removing the gearbox as it can damage the connector joint at the hydraulic thrust bearing.....
  1. Dual Mass Flywheel - OE or Not OE
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2010, 01:30 PM
  2. Need advice - broken dual mass flywheel
    By raveyd in forum Touran - Sharan - Caravelle
    Last Post: 21-02-2010, 11:43 PM
  3. Golf GT TDi 150 Dual Mass Flywheel
    By AAGT150 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-12-2009, 10:47 AM
  4. Dual mass flywheel
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-07-2009, 12:28 PM
  5. clutch replacement needs new dual mass flywheel???
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2008, 10:56 AM
