Thread: Windscreen Wiper Damage..
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Windscreen Wiper Damage..
    Southend
    Yesterday I was washing my new Golf and I could not get the windscreen wipers raised up... I've washed it lots of times before but never had a problem extending them. Yesterday they seemed to be stuck so I gave it more force than necessary and managed to get them up... No problem except I chipped some of the paint at the top of the bonnet and now the mechanism is damaged - i.e. they will not glide smoothly over the surface and also the left hand side wiper has made a small but thick graze over the very bottom of the glass.
    Obviously this was my fault for forcing them up, but I think they should have come up easily on their own as normal and I do not know why they didn't... I spent a good ten minutes trying different ways and in the end I just got so cross with it I applied too much pressure.
    I'm going to need the winderscreen washer mechanism re-aligned, a tiny touch up of paint and some glass filler (it's not cracked but 'scraped'.. like frosted ice). I guess the damage is probably around £100. Do you think my VW dealer will repair the damage and fix it under the warranty due to the mechanism appearing to have been faulty in the first instance or do you think they'll make me foot the bill? Anyone else had problems with their wipers for washing???
  2. Re: Windscreen Wiper Damage..
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Yes I've experienced the same frustration but left the wiper blades where they were for washing. Similar problem clearing snow . It is a bit annoying you can't raise wiper blades - must make changing blades a little harder ?
  3. Re: Windscreen Wiper Damage..
    Jan 2010
    uk
    Are you saying that on the mk6 you can't or aren't supposed to be able to lift the wiper arm off the screen as per normal?
  4. Re: Windscreen Wiper Damage..
    South London. UK
    Quote Originally Posted by lucid View Post
    You cannot or must not try to lift the blades away from the windscreen and up to 90 degrees unless you first put them into the 'Service' position.
    This is done by turning on the ignition then off again and then pressing the wiper stalk briefly downwards toward the floor. The wipers will then, and only then park themselves 90 degrees up on the windscreen where they can then be lifted away from the glass.
    If you do anything else you will damage arms, painted surfaces on edge of bonnet etc.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  5. Re: Windscreen Wiper Damage..
    Aug 2009
    West Yorkshire, Haworth
    Quote Originally Posted by HHGTTG View Post
    Respect to HHGTTG I had no idea you could do the above thanks for this info you know your stuff buddy keep it coming
    2010 Audi A3 Sportback Sport 1.4T, Ibis white
  6. Re: Windscreen Wiper Damage..
    Jan 2010
    uk
    Yes thanks i had no idea either.
  7. Re: Windscreen Wiper Damage..
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Nice one HHGTG , thanks ,
  8. Re: Windscreen Wiper Damage..
    South London. UK
    Read the manual. It could save you from pounds worth of damage.
    To put the wipers back to their parked position place them back on the windscreen then turn on the ignition and briefly flick down the wiper stalk again OR they will return, I believe, if you drive the car away.
  9. Re: Windscreen Wiper Damage..
    South London. UK
    The wipers are designed to sit parked below the rear level of the bonnet for protection and aerodynamics, I suppose. Therefore you cannot lift them away from the windscreen when parked. You must first get them into their 'service' position.
    See my other post as to how to achieve this.
  10. Re: Windscreen Wiper Damage..
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by moe360 View Post
    Yes it does tell you this in the handbook. Now depending on your handbook on a GTi/GTD Cleaning and changing windscreen wiper blades page 241. It has a supplement on how to put your wipers in the service position (arms and blades vertical) it says page 109 but its actually on page 112. Its actually in the main index at the end of the book under Windscreen wiper - folding back wiper blade.
    @brokinfan I don't think you will be able to claim under warranty.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. A6 Windscreen Wiper Problems (but not the usual)
    By 1299cc in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2009, 03:20 PM
  2. windscreen wiper disaster
    By big jase in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2009, 09:34 AM
  3. Rear Windscreen wiper not moving
    By TURBOPROP in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-04-2008, 02:45 PM
  4. A4 Avant Rear Windscreen wiper and washer problem
    By maudi25 in forum Archive posts
    Last Post: 18-01-2008, 10:45 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
