Thread: 1.9 tdi poor MPG
  1. 1.9 tdi poor MPG
    Aug 2009
    Barnsley
    Hi all,
    I’ve been getting really low MPG lately from my 1998 1.9 TDI (90bhp) which has been re-mapped. Been getting as low as 25/30 on normal runs.
    Had it hooked up to laptop with VAG software, no faults were showing up. Only things that looked like they could have been causing it was that the temp. sensor seemed to be showing cooler than what the engine was showing on VAG and taking longer to get up to temp.
    Other possibility was that when looking at the idle, 2 of the injectors were having to work hard to keep the engine running smooth, one unparticular was really up and down on the graph where as two of them was a perfectly straight line?? because of this he said that it might be the injector leaking and causing poor mileage.
    But im still unsure how i can check to see if they are leaking etc and does this sound like it good be a decent possibility??
  2. Re: 1.9 tdi poor MPG
    Pembrokeshire
    22 Post(s)
    the temp sensor , if giving a cooler reading will drastically affect mpg. i would change that first.
    is the low mpg since the remap or just started ?
  3. Re: 1.9 tdi poor MPG
    Aug 2009
    Barnsley
    Thanks for the fast reply.
    I got the car when it had already been done, its always been lower that what i had expected from it, but recently has seem to be worse, but guessing that could be down to the cold weather.
  1. 1.9 TDi help.....
    By Estoril Ben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2007, 10:52 AM
  2. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  3. A6 2.5 TDI Pierburg Maf????
    By FuNkYcHiCkEn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2007, 05:57 PM
  4. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
