Thread: Would you service after 4,000 miles?
  1. Would you service after 4,000 miles?
    curiousgeorge Guest
    I've had my car nearly a year now so I'm getting the service due in x days warning, but I've only done about 4,000 miles.
    Should I bother or wait a few more months? It's only £99 for the interim service, compared to £249 for the major service. I presume it's just plugs, filters and oil change.
  2. Re: Would you service after 4,000 miles?
    134 Post(s)
    2013 Post(s)
    Yes and change it to annual fixed interval servicing using Platinum oil, not Longlife.
  3. Re: Would you service after 4,000 miles?
    curiousgeorge Guest
    Thanks, will do. I presume because long life oil leads to sludge build up.
    I forgot to mention that I recently replaced most of my oil which had somehow been consumed or had leaked out. Does that mean it's not as urgent?
  4. Re: Would you service after 4,000 miles?
    134 Post(s)
    2013 Post(s)
    I am not sure about Longlife, I get a feeling it may not be as good as Platinum at protecting the engine if changed annually anyway and Platinum is slightly cheaper but Longlife 3 is a 5w/30 not 5w/40, the jury is out. Certainly LL3 does not cause sludge but whether or not it stops it compared to Platinum I would not like to say, or test it! Not on a car I was paying for anyway…
  5. Re: Would you service after 4,000 miles?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    If only doing 4K miles a year and it involves lots of short journeys there is a good case to made that the oil should be changed at 6 months ! If the oil does not get up to working temperature then a lot of combustion by-products will not be burned off and this will degrade the oil & cause wear. It is kinder to the engine to do 25mile + journeys rather than 5 mile ones even though the 25 mile trips may result in much greater yearly mileage.
  6. Re: Would you service after 4,000 miles?
    curiousgeorge Guest
    That's a good point, thanks.
  1. Question Mk3.5 Cabrio 'IN 02' message.
    By Hitby in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2009, 08:39 AM
  2. Do my own OIL/Filter change service
    By IMK1230 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-03-2009, 04:04 PM
  3. Service interval identification.
    By wackyracer in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2008, 09:35 PM
  4. Service History Opinions
    By audipersempre in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-02-2008, 06:56 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
