Thread: Retrofiting power latch rear door a4 allroad 2010
  1. Post Retrofiting power latch rear door a4 allroad 2010
    Aug 2009
    ATHENS GREECE
    i am starting the retrofiting of power latch oN my all road A4 2010. i have studied the ELSA 3.7 diagram at page 100/6.i am confident that i can make the harness according to the diagram.
    so far the way i see it is that :
    from j393 (conv,contr)REAR RIGHT, there are 2 cables for can bus going from pins 59,60 to motor 1 plug t8 pins 3/7.
    power 12 + going into t8 pin8 motor 1 and t10 pin10 on motor 2.
    ground is on pin t8/4 motpr 1 and t10/4/9/ on motor 2.
    also pin t8/5 motor 1 goes to e405 pin 2 (opening button)
    and finaly pins t8/2 /6 are bridged with t10/6/2.i havent found the part number for the plugs yet from motors to the controller.
    can any one verify this and share my ideas?
    i found the motors on ebay for 69 euros so perhaps it is a good retrofit ...
    ARI
  2. Re: Retrofiting power latch rear door a4 allroad 2010
    Bratty Guest
    a ristidis, you are obviously very talented
    (reversing camera retrofit) and I believe that you actually enjoy the challenge of these retrofits.
    But is it not easier to just fit actuators instead of gas-struts (or stronger gas struts) that when you press the button on your keyfob to open the boot that it does it on its own, no electrics etc.
    Might be more difficult to close the boot but the correct combination or the right strut might have the desired effect.
    Dunk
  3. Re: Retrofiting power latch rear door a4 allroad 2010
    Aug 2009
    ATHENS GREECE
    thank you for your kind compliment i am trying to keep every retrofit within factory specks ,i also love the challenge and since i can understand the schematic ,it does not appear to be difficult at all. so far i have concluded that i need the motors ,the brackets (8k9827603 A ) as well as the plugs in order to make the harness. basically it is power from ST1,2 ground and can bus so i will keep everyone posted.
    If sm can give me some info on the plugs part numbers it will help a lot. am also doing towing retrofitting and then memory driver's seat module.
    thanks for the great forum ,hepls a lot
  4. Re: Retrofiting power latch rear door a4 allroad 2010
    Aug 2009
    ATHENS GREECE
    Quote Originally Posted by Bratty View Post
    Dunk
    hello I stuck ,missing the L shape brackets that connect the rotating part from the motor to the hinges.i have attachd some photos.can you tell me if any part number on those ?thanks
    ARI
  5. Re: Retrofiting power latch rear door a4 allroad 2010
    Mar 2009
    Hi aristidis,
    I bought the two motors too, and i will buy the kufatec cables, i think will look better then make new cables don't you think?
    I have the A4 allroad 2010 model, do you know the vag codes to ative this? And do you know if will work with any conv. model?
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. World Debut For The All New Audi A3 Cabriolet
  5. How does the Quattro system work?
