20-09-2010,06:25 PM
Originally Posted by
pitch3110
In Suffolk I am afraid but many thanks for the offer.
Just enable radio - setup - then pressed setup and retuirn and no have a screen saying 'ENGINEERING' at the top and under that 'not yet intialised'.
Trouble is it will not go away. Now going to reboot it.
Am I right in thinking 'CAR + SETUP' will bring the hidden menu up??
ta
Pitch
Hi Pitch,
To get out of the Engineering menu, either press and hold SETUP and Return for a few seconds, or reboot the MMI.
CAR and SETUP will only display the Hidden Menu if the option to do this has first been activated using VCDS, so if you can't get into it, you will need to find a friend with a VCDS cable to activate the option for you.
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
