Thread: HELP ~ ERROR CODES vw passat 55 reg
  1. Unhappy HELP ~ ERROR CODES vw passat 55 reg
    Feb 2010
    Wolverhampton, UK
    Hello everybody
    Going through a rough patch with my passat for the last couple of weeks when it broke down on M6 in the middle of nowhere.
    Am having engine management light and glow plug light flashing for quite some time. Engine management light is on for couple of months whereas, glow plug light came on after the break down at M6 in Feb 10. Have the problem with injectors sorted but the flashing light is still there.
    So went to local VW dealer and as I am buying a Golf the sales man as a goodwill gesture had the diagnostic done free of charge (otherwise £ 80).
    So here is the list of fault codes and faults that I received today:
    A total of 9 trouble codes:
    19557 - P3101 - 009
    Intake Flap Motor - V157
    Open Circuit/Short circuit to ground - Intermittent
    19558 - P3102 - 006
    No signal - Intermittent
    17075 - P0691 - 007
    Cooling Fan 1 Control Circuit Low - Intermittent
    17055 - P0671 - 006
    Cylinder 1 Glow Plug Circuit - Intermittent
    17056 - P0672 - 006
    Cylinder 2 Glow Plug Circuit - Intermittent
    17057 - P0673 - 006
    Cylinder 3 Glow Plug Circuit - Intermittent
    17058 - P0674 - 006
    Cylinder 4 Glow Plug Circuit - Intermittent
    17678 - P1270 - 006
    Unit Injecor solenoid valve - cylinder 4 N243
    Value above upper control limit - Intermittent
    16618 - P0234 - 006
    Turbo/Super Charger Overboost Condition - Intermittent
    Well thats it hummm!
    Although the car is running but not at its optimum level and even the drive is not like before.
    Are the above faults very serios, I am planning to see my mechanic over the w/end. However, in the meantime any help and guidance will be much appreciated.
    Kind regards
    Malik
  2. Re: HELP ~ ERROR CODES vw passat 55 reg
    Sep 2009
    London
    19558 - P3102 - 006
    http://wiki.ross-tech.com/index.php/19558/P3102/012546
    17055 - P0671 - 006
    http://wiki.ross-tech.com/index.php/17055/P0671/001649
    17056 - P0672 - 006
    http://wiki.ross-tech.com/index.php/17056/P0672/001650
    I'm guessing:
    17057 - P0673 - 006
    17058 - P0674 - 006
    Cylinder 4 Glow Plug Circuit - Intermittent are the same faults.
    17678 - P1270 - 006
    http://wiki.ross-tech.com/index.php/17678/P1270/004720
    16618 - P0234 - 006
    http://wiki.ross-tech.com/index.php/16618/P0234/000564
    If you ever need to know what fault you are dealing with, then go here:
    http://wiki.ross-tech.com/index.php/Main_Page and put the beggining fault numbers into the search bar.
    2004 golf mk5 with retrofitted: cruise control, MFSW, Highline clock diplay, angel lights.
  3. Re: HELP ~ ERROR CODES vw passat 55 reg
    Feb 2011
    swansea wales
    Quote Originally Posted by taurus_tem View Post
    19558 - P3102 - 006
    17055 - P0671 - 006
    17056 - P0672 - 006
    I'm guessing:
    17057 - P0673 - 006
    17058 - P0674 - 006
    17678 - P1270 - 006
    16618 - P0234 - 006
    i'm getting some similar problems with my 06 passat 2.0tdi. scanner shows
    1.cylinder 4 p0674 elec fault,
    2. pump jet valve cylinder 4 N243, regulation range exceeded p1270
    3. pump jet valve cylinder 1 N240, regulation range exceeded p1261, sporadic 006 - short to plus.
    im guessing fault 1. is possible glow plug fault. faults 2 and 3 not really sure, what is 'pump jet valve' referring to? or can fault 1 cause faults 2 and 3.?
    the wiring glow plug / injector harness was replaced about 5 mths ago.
    i'm new here, any help v v much appreciated!
  1. Please Help Warranty Query for 2.5 year old UK Passat Exported To Ireland
    By jaay in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-08-2010, 11:38 PM
  2. What no more Longlife 2 oil ??
    By kimsue in forum Touran - Sharan - Caravelle
    Last Post: 12-08-2010, 04:40 PM
  3. Passat 55 Reg - P3101, 3102 & 0691
    By Tariq Malik in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-03-2010, 04:44 AM
  4. Vw Passat 4motion Estate Voted Towcar Of The Year 2007
    By Ben in forum Chat - Anything with wheels
    Last Post: 26-08-2007, 07:35 AM
