Thread: Faulty Instrument Cluster
  1. Faulty Instrument Cluster
    Jan 2010
    Macclesfield England
    A couple of days ago my instrument cluster started coming off and on, however it is now off 90% of the time i would say, when this happens, the speedo, rev counter, temperature gauge and fuel gauge does not work, however the clock and indicators and light signs do. I would appreciate any ideas on what the problem is
  2. Re: Faulty Instrument Cluster
    Jun 2010
    Isle of Skye, Scotland
    Hi, I had the same thing go wrong with my A3 1.9 TDi 130 about 2 years ago and it was slowly driving me mad. The electrical fault also affected the car alarm so it would go off about 15 mins after parking if I'd driven the car for a short distance and not given the engine a chance to warm up (or that's what it seemed like). If I drove longer and the engine warmed up it never happened so I used to find myself driving around at stupid o'clock to warm the engine up then get some sleep! If the needles flickered etc, the alarm would go off and if they never flickered I knew I would get some peace.
    It was the instrument cluster itself that needed replaced. I enquired about getting one from a scrappy's but Audi need to match it to the key fob so they really need to do it. It cost me £150 at a main Audi dealer which I didn't think was too bad considering the hassle the fault caused me. It solved the problem and I'd put up with it for ages thinking it would be a lot more expensive to fix. Word of warning, mine started as the instrument cluster flickering once in a while to more regular and then to the alarm problem I described, getting more frequent the more I left it.
    Hope this helps.
  3. Re: Faulty Instrument Cluster
    May 2008
    Glasgow,Scotland
    Hi there no need to go to a scrappy just send your unit to the link below i got my a4 cluster repaired for £140 and you dont need to re-code the unit they repair check it over and send it back within a couple of days a very good eficient service.
    http://www.clusterrepairsuk.co.uk/repair-list/audi/a3/
  4. Re: Faulty Instrument Cluster
    May 2010
    stoke on trent
    My cluster in my A3 is faulty and am going to send it to these people, one problem, how do i get the cluster out to send it? any help appreciated!
  1. Touran 2003 instrument cluster failing
    By jugglerb in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2012, 12:12 AM
  2. Retrofitting an updated instrument cluster?
    By brollah in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2009, 04:01 PM
  3. Instrument Cluster Replacement
    By nisiotis in forum VCDS - General Questions
    Last Post: 03-04-2008, 02:10 AM
  4. Removing the instrument cluster
    By marshy26 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2008, 06:25 PM
  5. Intermittant instrument cluster
    By allgolf in forum Golf MK3 - 1993 - 1999
    Last Post: 17-01-2008, 06:10 PM
