Thread: Steering wheel removal?
Results 1 to 8 of 8
  1. Steering wheel removal?
    I've just bought a s-line steering wheel from a 2004 1.8t ,im going to put on my 2002 tdi sport.What i want to know is it easy to change them and how do you do it.
  2. Re: Steering wheel removal?
    May 2008
    Finland
    It's not necessary to remove the battery ground, but I recommend you do it anyway and wait a few minutes to minimize the risk of the airbag going off accidentally.
    1.) make sure your ignition is switched OFF and key is out of the ignition
    2.) remove the airbag. 2 Torx-screws at the back of the steering wheel, unplug the connector and place the airbag face up on the ground / table, etc.
    3.) The steering wheel is held on by an XZN 12 screw. Mark the position with a pen if it hasn't been marked already and remove the screw. Pull out the steering wheel
    4.) Reverse for installation of the new wheel
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  3. Re: Steering wheel removal?
    cheers
  4. Re: Steering wheel removal?
    Tullamore, Ireland
    I've read in a few different posts/websites that if you are removing the airbag then you should disconnect the battery negative while you have the ignition turned on! I've done it this way a good many times now without incident. Anyone any comments?
  5. Re: Steering wheel removal?
    May 2008
    I never bother, can't see the point. It's always been fine with the battery connected.
  6. Re: Steering wheel removal?
    what size xzn 12 socket is it?
  7. Re: Steering wheel removal?
    Nov 2008
    Leeming
    Quote Originally Posted by choimaloy View Post
    Torx T55
  8. Re: Steering wheel removal?
    Jul 2009
    wales
    have you got any pic's mate ?
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  4. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
  5. How does the Quattro system work?
