Thread: B6 S4 badge removal
  1. B6 S4 badge removal
    Jun 2009
    Oxfordshire
    Hello.
    How are the front grille and rear S4 badges attached on the B6 S4? I'm guessing glue for the rear badge but is the one on the grille secured by pins through a backplate?
    TIA.
  2. Re: B6 S4 badge removal
    Mar 2009
    London
    Hello mate, I have an S-Line and the front badge on the grill is secured by pins (the bracket with pins cost a couple of quid from the Audi dealer), haven't had to change the rear or side badges but they look like they're glued on.
    The bracket is specific to the chassis so make sure you get the right one, it's fitted from the rear so you need to pop the hood and push it through from the back of the grill.
    04 A4 1.8
    T S-Line Multitronic (190bhp)
    Misano Red - Factory RS6 18" Alloys - Rear Folding Seats - Park Distance Control - Private Number Plate
  3. Re: B6 S4 badge removal
    Jun 2009
    Oxfordshire
    Nice one. Thanks.
    I'll be removing the badges from the S4 that I'm hoping to buy shortly so I don't plan to put them back on.
  4. Re: B6 S4 badge removal
    Mar 2009
    London
    Cool, I misread and thought you were trying to stick them on
    Taking the front badge off the grill isn't too difficult but it's a tight fit and much easier if you use a small screwdriver wrapped with masking tape (so as not to scratch the grill) to gently prise open the pins
    04 A4 1.8
  5. Re: B6 S4 badge removal
    Southern County Softy
    20 Post(s)
    To remove the glued on badges try dental floss in a sawing motion behind the badge then clean off the excess glue with WD40
    A4 2.5 tdi QS (mapped)
  6. Re: B6 S4 badge removal
    Jun 2009
    Oxfordshire
    Thanks kite.
    The consensus seems to be fishing line/dental floss followed by WD40 to clear up the remaining glue.
  1. Question S4 (B5) Vs S4 (B6)....
    By grainqey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2011, 08:05 PM
  2. B6 Estate multiple Trim removal
    By LeFrog in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-04-2010, 07:20 PM
  3. S4 Review...
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-05-2009, 09:24 PM
  4. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
