Thread: Dip Stick Casing
  1. Dip Stick Casing
    I have a 99 A3, the casing that holds the dip stick has cracked and the top has broken away. Is it an easy thing to change or do I need to get a mechanic to do it?
    Also roughly how long would it take a mechanic to replace it and how much does the new part cost (approx)
  2. Re: Dip Stick Casing
    Jan 2009
    towcester northants
    push fit but can be very tight
    cant remember how much but last one i did was about £7-8 i think
  3. Re: Dip Stick Casing
    cheers, do you think i need to have it up on a lift or can i get it from under the bonnet?
  4. Re: Dip Stick Casing
    Jan 2009
    towcester northants
    if its just the orange plastic part you should be able to do it on the floor
  1. Dip Stick!
    By Foringo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-03-2014, 09:57 PM
  2. Dip stick...
    By oli1708 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2009, 10:54 AM
  3. passat dip stick
    By gpaul in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-08-2009, 05:02 PM
  4. Question Passat brake fluid cap and dip stick required.
    By matt111074 in forum Early Passat Forum - Pre 97
    Last Post: 25-04-2009, 01:39 PM
  5. Audi 2.8 auto dip stick
    By roogy in forum Chat - Anything with wheels
    Last Post: 27-04-2007, 09:05 PM
