Thread: VAGCOM and B5.5 what lead?
Results 1 to 8 of 8
  1. VAGCOM and B5.5 what lead?
    Feb 2010
    uk
    Hi all, i need to know which of the cheap leads will work with 409.1 and my car. Its a 53 plate 130 sport estate.
    I have looked on ebay and they all say
    Passat MK 3
    16 Pin
    YES
    Passat MK 4
    16 Pin
    YES
    Passat MK 5 (B6)
    16 Pin
    NO
    Passat MK 6 (B6)
    16 Pin
    NO
    So, have i got a MK4 or 5?
    Will this lead work only want to switch off my eair bag light as since taking the dash out it wont go out and yes, everthing is connected as it should.
    Many thanks
  2. Re: VAGCOM and B5.5 what lead?
    Norfolk
    Yes it will work. I would by it from Ilexa or Gendan, not from ebay. It will work better if you pay ross-tech for the full licence.
  3. Re: VAGCOM and B5.5 what lead?
    Redditch
    Leave the Ebay one well alone!
    I don't like the look of it purely because they called the mk5 and 6 both a B6 - which is wrong!
    If you want it to work, and you don't wanna risk messing your ecu up (there was a scare not so long ago about cheap ebay cables causing shorts) then visit Ilexa or Gendan to get a Ross-tech one like Martin said.
  4. Re: VAGCOM and B5.5 what lead?
    Feb 2010
    uk
    I have taken a punt on an ebay one. It looks identical to the one on Gendan but half the price
    I only want to reset the airbag light which i can do with the shareware version of vagcom.
    I think i heard about a problem with later cars with non factory radios, somthing to do with K-link or something
    If i have further problems and need vagcom i will get the proper kit and pay for a full version.
    Thanks for the help
  5. Re: VAGCOM and B5.5 what lead?
    Quote Originally Posted by Rexer View Post
    Passat MK 3
    16 Pin
    YES
    Passat MK 4
    16 Pin
    YES
    Passat MK 5 (B6)
    16 Pin
    NO
    Passat MK 6 (B6)
    16 Pin
    NO
    Many thanks
    Go for the Ł8 lead, I have bought 3 cheap Ebay leads and they all work fine with 409.1 on my B5.5.
    Cant see the point of paying Ł20 for the same lead (they are all made in China). I see on one site that you cant use 409.1 with Vista, strange as I have been doing this for the last 3 months with no problems.
    If you get one pay the $99 to register the softwear, its well worth the money.
  6. Re: VAGCOM and B5.5 what lead?
    Merseyside
    My Ł15 ebay lead works with no problems. Also works fine on Windows 7 with Vag-Com 409.1.
  7. Re: VAGCOM and B5.5 what lead?
    Feb 2010
    uk
    The one i got was Ł11, and i have vista but already found out how to sort it if i do have problems (run as admin)
    Will definatly pay the $99 as it will serve me well. We have a bora 150 PD and now the Passat
  8. Re: VAGCOM and B5.5 what lead?
    $99 well spent
    be good to know if that lead works ,before i commit to buying one.
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. B5.5 half cut
    By adrianjin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-12-2009, 09:52 AM
  3. B5 seats into a B5.5?
    By Gizmo68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2009, 10:53 AM
  4. B5.5 front end
    By 808 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2009, 07:23 PM
