Thread: Central Locking Golf Mk4
Results 1 to 10 of 10
  1. Central Locking Golf Mk4
    Mar 2010
    Yeovil UK
    Hi realise there are all sorts of threads and solder joints on door modules seem most likely cause but trying to work out which one.
    Only drivers door opens from remote and drivers door key in the lock. However the using door card switch to open all doors does exactly that. So how do I work out which door is the problem, how do I narrow down the faulty module?
    If the convenience is likely where is it?
    The alarm appears to work as red light flashes and can hear the second pulse of deadlocks.
    Many thanks for any help.
  2. Re: Central Locking Golf Mk4
    Oct 2009
    Newcastle
    Quote Originally Posted by MalHD4 View Post
    Have you tried pressing the open door button on the key twice?
  3. Re: Central Locking Golf Mk4
    Mar 2010
    Yeovil UK
    Yes tried the key fob twice, thanks. Also discovered the boot only opens if the key slot is vertical.
  4. Re: Central Locking Golf Mk4
    Sep 2008
    Hi, I also have exactly same problem on my 52plate so any advice wud be ace !!
    Keith
  5. Re: Central Locking Golf Mk4
    Jan 2009
    North Manchester
    The convenience module is located under your steering wheel (although try other things before you conclude on the convenience, because it isn't cheap). You will need a T20 screwdriver to unscrew all the plastics underneath the wheel
  6. Re: Central Locking Golf Mk4
    N/A
    I had the same problem with my anniversary a few years back, all i did was to disconnect the battery for 5 mins and everything sorted itself
  7. Re: Central Locking Golf Mk4
    Feb 2009
    Hi. I have the same problem on my golf 2.0. Only, 2 doors does not lock automatically when driving...so i hit the button twice on my drivers door and it locks. Works fine, but wish it could be fixed. Any ideas??
  8. Re: Central Locking Golf Mk4
    May 2010
    Stroud
    Hi All,
    I'm a new owner of a 2003 Mk4 Golf 1.6 auto. When we picked it up the fob would only unlock the drivers door (even when pressed twice) yet the key and door card worked fine. Having read various forums there was a suggestion to disconnect the vehicle's battery for 5 mins. 5 mins hahahahahaha !! After about 5 seconds the alarm went off !! So, without the battery connected the fobs wouldn't silence the alarm and turning the ignition on didn't work either, obviously. Now in a state of sheer panic, I reconnected the battery (can't have been disconnected for more than 45 secs) and now the fob unlocks all doors (and boot) on the sceond press of the button. Re-sync'd the front windows for up & down as per the manual.
    So, OP, try disconnecting the battery (watch out for the alarm going off) and reconnect ?
    Cheers,
    Chris
  9. Re: Central Locking Golf Mk4
    Jul 2008
    So. is there a way to stop the alarms going off when you disconnect the battery?
  10. GOLF Mk6 4 DOOR AUTO LOCK ING
    Feb 2010
    BRADFORD
    Hi just got a new golf so far so good 1.6 tdi the thing is my last 6 car's have had AUTO LOCKING DOOR'S the golf's hand book say's you can set this up to auto lock at 5 or 10 mph but i cant find how to do this do i have to go back dealer too have it done ( at a cost ) can any body help me with this ...thank's
  1. Question Remote Central Locking?
    By ImCammers in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2010, 12:05 PM
  2. Please Help Golf Mk4 Central Locking
    By ads22 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-12-2009, 09:49 PM
  3. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 17-09-2009, 08:43 AM
  4. Faulty Central Locking - GT TDI Mk4
    By Aust1n in forum Golf MK4 - 1999 - 2004
    Last Post: 03-05-2009, 04:19 PM
  5. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
