Thread: New guy with a headache LT46 speed limiter
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: New guy with a headache LT46 speed limiter
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    AIUI this can be done fairly easily if you go direct to the EEPROM chips on the ECU rather than via the "controlled" interface that VCDS type tools use. A good forum for looking at how to make this sort of change is MHH Auto - for example: Speed limiter in eeprom EDC17CP20 (VW T5). I'm not sure where you would post there to help you find someone local to do the work though.
  2. Re: New guy with a headache LT46 speed limiter
    1840 Post(s)
    When VCDS and ODIS says this cannot be reversed when brought down, does that include going direct into the eprom? My life stops at the ECU plug.
  3. Re: New guy with a headache LT46 speed limiter
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    I think it can still be adjusted going direct to EEPROM. Everything the ECU knows is in the firmware, flash, EEPROM, etc, so it's like rewinding time for it to what it "knew" previously. Some devices (but not the ECU AFAIK) have additional hardware "tripwires" such as on-chip links / fuses they will blow when certain programming is done so they still know something happened. Even then getting a new chip with links intact can bypass that.
  4. Re: New guy with a headache LT46 speed limiter
    Apr 2021
    Tamworth
    Hi could you sent me the details of the company who took your speed limiter off you VW lt 46. Cheers Craig
  5. Re: New guy with a headache LT46 speed limiter
    May 2022
    Aberdeenshire
    Hi The mills, I am also in the position of having a LT46 down rated but restricted to 55mph could you please tell me where you had to send you ECU to to get the limiter removed.
    Much appreciated
    Cammy.
  6. Re: New guy with a headache LT46 speed limiter
    Oct 2022
    Uk
    Hey,
    Is your van completely derestricted now? There no other speed limiter other then the ecu?
    What company did you use?
    I have an lt46 with a tacho and the painful 56
    Thank you
  7. Re: New guy with a headache LT46 speed limiter
    #17
    Oct 2022
    Uk
    Hey do you have the info on the guy to derestrict my ecu? Thank you!
  1. LT46 speed limiter reset
    By charliebucket in forum The Commercial Range
    Last Post: 02-09-2009, 07:51 PM
  2. In-Car Speed Limiters Go On Trial In London
    Last Post: 12-06-2009, 05:46 PM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. Speed Awareness Course
    By prolfe in forum Chat - Anything with wheels
    Last Post: 08-06-2007, 01:35 PM
  5. Replies: 0
    Last Post: 03-12-2005, 07:54 PM
