Thread: Fitting Remote servo anyone got advice please
Results 1 to 10 of 14
  1. Fitting Remote servo anyone got advice please
    mk1quinny Guest
    Hi im having fitted one remote servo to my car heres some pics of my bay its modified and smoothed and want to improve braking a bit as i use it more daily than it was intended
    So i have mk2 master cylinder fitted on the drivers side
    im having a remote servo put in passengers footwell i think but if cant get it to fit there going to have to go in my bay may have to move washer bottle or battery.
    now it looks like im having the servo run off the front brake lines as they do most of the raking then have a bias valve fitted to even out the braking front and rear
    has anyone fitted one or done anything different it says on the servo sites that with twin circuit brakes like mine you should run two remote servos but there just too bulky so im sending one back
    hope someone has some suggestions oh and im not buying a pedal box system as i dont have the cash for one
  2. Re: Fitting Remote servo anyone got advice please
    Jan 2009
    towcester northants
    rover sd1 3500 used to have remote servos have a look at one of those or there used to be a mod on mk1/2 polos that used remote servo but that was something that was done via an old dealer i worked for
  3. Re: Fitting Remote servo anyone got advice please
    Jun 2009
    Notts
    why not just fit a 1.9tdi polo servo in the engine bay located same place as your master now... Its nice and small and cope well with twin lines.... I'm running it with brembo fronts and tt calipers rears.. Wilwood bias for each line to rear...
    MK1 CAB.. 1.8tt (AUM) - TT back box - Full TT dash - Intergrated TT lights - Full Koni Suspension - 928 Rims - Porsche Brakes converted to 280mm - DTA ECU - ABS sensors all round but not used for braking - Full electric Pack.. Loads more..
  4. Re: Fitting Remote servo anyone got advice please
    Sep 2007
    Essex boy in Suffolk
    Quote Originally Posted by willowraf View Post
    Hi willowraf,
    which year of polo is that off, does it fit fine with the 1.8T fitted?
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  5. Re: Fitting Remote servo anyone got advice please
    Jun 2009
    Notts
    Quote Originally Posted by Borab0y View Post
    Hi willowraf,
    Mine was off a 2003 polo 1.9tdi... Also yes it does fit perfectly with a 1.8t fitted....
  6. Re: Fitting Remote servo anyone got advice please
    Sep 2007
    excellent, thanks
    dont suppose you have a picture of it fitted, this sounds like a great solution
    Graham
    Golf 6 .:R
  7. Re: Fitting Remote servo anyone got advice please
    134 Post(s)
    2007 Post(s)
    Two of these but God knows where you would hide them!
    https://www.europaspares.com/BRAKE_P...RSBU_6514.html
    One other thing, I have just done twin 40’s on an 8v and had a sketch with the servo pick up, you will need an old servo line to pinch the valve from and some VW servo hose. I had Pirtek make me up a banjo union to bolt into the un-machined boss on the inlet manifold which I had drilled and tapped out by a local engineer. You will also need a suitable T or Y piece if you use two servo's.
  8. Re: Fitting Remote servo anyone got advice please
    Jun 2009
    Notts
    excellent, thanks
  9. Re: Fitting Remote servo anyone got advice please
    134 Post(s)
    2007 Post(s)
    Which PS rack are you using?
  10. Re: Fitting Remote servo anyone got advice please
    Jun 2009
    Notts
    Sameone that your fitting to your long time project....
    Original TSR Rack!!! "Bluebird" me thinks...Looks exactly the same....
  1. fitting a servo
    By melanie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2008, 05:36 PM
  2. Fitting Remote central locking
    By Buwgafa in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2007, 07:46 PM
  3. Advice on fitting new temp switch please
    By leslie9 in forum Archive posts
    Last Post: 12-11-2007, 08:05 PM
  4. Remote start
    By loki in forum Archive posts
    Last Post: 27-10-2007, 11:33 AM
  5. 1998 Polo - New Car Stereo Fitting Advice
    By mgclarke in forum Polo - Derby - Lupo - Fox
    Last Post: 30-05-2007, 04:49 PM
