Thread: conlog alarm help
  1. conlog alarm help
    Oct 2009
    luton uk
    Hi I have a 1997 golf mk3 cabriolet which is fitting with a dealer fit conlog alarm not sure the model ?, I would like to remove but I cannot seem to be able to find the main control I know the siren is in the engine compartment and a small unit that looks like it could be a shock sensor is behind the glovebox, I've taken the instrument panel out and tried folowing the wiring it but it seem to just go behind the dash on the drivers cannot see or feel any control unit any ideas ? Also does any one have a wiring diagram for any conlog alarm
  2. Re: conlog alarm help
    Jun 2008
    Lichfield, Staffordshire
    Hi, have a look at the siren under the bonnet, if it's fed with 2 wires, it's just a siren, if it's 3 or 4 wires, it's a battery backed siren, and if it's more wires than that, then the control box is IN the siren ! (also has a valet key switch on the back).
    If that's not the answer, have a look down the plastic panel behind the bonnet pull handle.
    hope this is some help.
  3. Re: conlog alarm help
    Apr 2009
    I'm removing the alarm from my MkIII GTi at the mo...
    I finally found the control unit behind the drivers side fresh air grill. You'll need to pop out the light control switch unit, then undo the four screws in the grill panel.
    The control box is bolted into it's own little casing.
    If anyone has advice on removing an alarm (the wiring side of it) it'd be really appreciated... The back of the fuse box looks kinda scary...
    Cheers,
    Phil
  4. Re: conlog alarm help
    Feb 2021
    Hampshire
    I know it's old but did anyone ever get back to you regards the wiring to remove this crap alarm
    I'm doing it now and need help!!
  5. Re: conlog alarm help
    1837 Post(s)
    They were nothing but trouble, I can't remember how many I took out and replaced with GT. It is going back some decades but I remember it being a big box stuffed up above the relay plate.
  6. Re: conlog alarm help
    Dec 2020
    Your not going to thank me because all the loom is black wires which have numbers on them which your supposed to remove after install, i have (not boasting) a full brand new one which i keep as a spare somewhere.
    it may not be the same model as yours though.
  1. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  2. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  3. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  4. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  5. A4 - B6 alarm problem
    By xenon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2007, 05:00 PM
