Thread: timing mark question
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. timing mark question
    Dec 2006
    hi friends,i have a mk3 1.6 8v with engine code AEK because i experience a hesitation on WOT between 2200-2800 rpm and have repalced almost everything i decided to check the timing marks between camshaft,distributor and crankshaft-flyweel but i cannot determine the flyweel mark.The mark i found i beleave is not the TDC mark but it is for firing.is this the TDC mark?
    thanks
  2. Re: timing mark question
    131 Post(s)
    1978 Post(s)
    That is one of the two lugs for the VW timing display system which uses an inductive sensor, the mark you want for the valve timing is a rather indistinct cast in dot that is only clearly visible if you remove the green plug and you will need a 27-mm hex key for this or a bolt with a 27-mm head. When the crank is at zero, there is also a mark on the front pulley that aligns with an arrow on the plastic lower casing but this mark is not as accurate as the one on the flywheel. There may be another mark on the flywheel which is about 12-mm away from the dot but still between the two big lugs and this is more of a diamond shape and more distinct, this is the stroboscopic timing mark to be used with a timing light to set the ignition timing but this is not used on the AEK, all you need to do is ensure that the dead centre of the rotor arm aligns with a notch on the thin top edge of the distributor body when the cam and crank are set at TDC.
  3. Re: timing mark question
    Dec 2006
    so this is not the TDC mark?i checked that when the camshaft pulley is on the OT mark the distributor is at No1 cylinder but i have not check the crankshaft because i am not sure for the mark on the crankshaft pulley is alligned with the plastic arrow.I also notice that the rotor shaft of the distributor has a little free play,is it normal?
    thanks
  4. Re: timing mark question
    Dec 2006
    ok i just removed the plastic 27mm female plug and found that i am ok on the TDC where is a line on the flywheel then i am ok on the OT mark on camshaft and ok on the distributor rotor,timing is ok.Thank you very much for the help.I stil cannot find solution for the hesitation on WOT on low rpms,any help will be much appreciated.
  5. Re: timing mark question
    131 Post(s)
    1978 Post(s)
    No, as I said, that is not the TDC mark it is one of the two inductive timing sender pegs and of no use to you, the TDC mark is a small cast in dot in between the two inductive timing pegs. Free play in the distributor is correct.
  6. Re: timing mark question
    131 Post(s)
    1978 Post(s)
    Get a fault code read done.
  7. Re: timing mark question
    Dec 2006
    when the OT on camshaft sprocket,the deep line in the crankshaft auxilliary pulley and the distributor are alligned i can see on the flywheel a deep line alligned with the housing and it can be seen as you said me when the plastic hex cap is fully removed,do you know if this line on the flyweel is the TDC?
    I have scanned for codes with vag com and do not have faults
  8. Re: timing mark question
    Dec 2006
    it has an inductive speed sensor near the oil filter on the transmission bellhousing so i beleave this is for triggering the speed(crankshaft sensor) then.
  9. Re: timing mark question
    131 Post(s)
    1978 Post(s)
    The sensor in the block is the crank speed sensor (G28) which provides the ECU with engine speed info for ignition timing, the sensor in the distributor (G40) tells the ECU where number 1 cylinder is so the ECU can provide sequential injection and the spark is distributed in the time honoured way. The mark on the flywheel can be a line and if that line coincides with the mark on the front pulley aligning with the arrow on the timing belt cover, then the engine is at TDC 1&3, if the OT mark aligns with the arrow, then the engine is at TDC number 1.
  10. Re: timing mark question
    Dec 2006
    Ok your info is very detailed and thank you very much.I checked and i am on marks so timing is correct.
    I dont know if the timing belt is low on tension and that is dangerous because i can pull the belt from the crankshaft pulley with strenghth of course is it normal?I also cannot find solution for the hesitation,is there any possibility to hesitate from the ISV?(idle stabilization valve).
    thanks
  1. Question mark 4 gt tdi timing belt
    By meaney22 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2009, 03:39 PM
  2. Question A4 Tdi Timing mark locations??
    By vespa86 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-06-2009, 08:41 PM
  3. Timing Belt Question for Audi A6 Avant
    By pandasharka in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 06-04-2008, 05:43 PM
  4. 1.9 TDI 90BHP (66KW) AGR timing question
    By 80sport in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2008, 03:58 PM
  5. Timing belt stripped,tensioner broke, Cam question, Please Help
    By tchrgrl in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 03:09 AM
