Thread: mk1-mk3 engine swap?
Results 1 to 10 of 12
  1. mk1-mk3 engine swap?
    May 2007
    I know that mk2 golf engines will fit in a mk1 but will a mk3 engine also fit without changing the engine mounts?
  2. engine change
    Mar 2007
    coventry
    if you can be a bit specific which engine 2.0l 8valve or
    May 2007
    The replacement engine is a for a mk1 karman it currently has a 1.5 or 1.6 depending if you believe the V5 or my local kwik fit?
    Im looking to put anything diesel in but not only that i plan on running it on chip fat. There are several web sites listing compatable diesel/chipfat engines. My first step is to find out what will fit in the car.
    The biggest problem so far is finding a scrap deisel mk1/2. There seem to be many more mk3 diesel about.
    Im not actualy mad. Im an engineering student......
  4. diesel power
    Mar 2007
    coventry
    wow this is what i wanted to do but with a vw caddy
    but with a tdi engine
    May 2007
    there is a caddy on ebay now Item number: 270122463005
    will prob go around £150 might make a good project.
    7 Post(s)
    Good luck !
    I'd love to plonk a PD diesel lump into a MK1. Either that or an IHI'd 1.8t
    It would fly !
    Aug 2006
    Devon, UK
    There are plenty of MK2 Diesels about. I saw several on Ebay recently. Go for the MK2 GTD if you want decent performance, it's a great engine and great with Biofuel. There seem to be less of the normally aspirated Diesel cars about as they just fall into disrepair. They're still good for Bio though.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
  8. Re: mk1-mk3 engine swap?
    Mar 2007
    coventry
    how are you getting on with this project?
    no matter how you try you always come back to what you first started
  9. Re: mk1-mk3 engine swap?
    May 2007
    Hi, slow but nearly finished. The engine and box fitted in with no problem, the exhaust however was a very different story. The main problem came from the choice of running gear and drive shafts. I originally chose to use MK3 shafts and so had to use MK3 hubs, rods, ball joints...... This does not work! If you do swap a TDi into a caddy the trick is to use the original drive shafts but the TDi bearings to connect to the gear box. As soon as my new brake master cylinder arrives I'm off for the m.o.t.
  10. Re: mk1-mk3 engine swap?
    Feb 2007
    Hertfordshire/North London
    Mate of mine shoe horned a VR6 engine into his, don't know how, but it's impressive and another mate has put a 1.8T in his Mk1
  1. Engine Swap
    By Macyzfman in forum New Member Introductions
    Last Post: 06-11-2007, 09:55 PM
  2. engine swap
    By druscirocco in forum Scirocco - Corrado
    Last Post: 26-08-2007, 04:09 AM
  3. MK3 2.08V > 16V swap
    By gti_8v in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2007, 12:04 AM
  4. engine swap
    By sokbrock in forum Chat - Anything with wheels
    Last Post: 10-04-2007, 01:39 AM
  5. Audi Avant 90 to 110bhp engine swap
    By mikethebike in forum New Member Introductions
    Last Post: 26-11-2006, 12:46 PM
