Thread: SD cards m3u 99 songs?
Results 1 to 10 of 13
  1. SD cards m3u 99 songs?
    Jul 2007
    Bucks, UK
    I've been playing with the SD cards on the RNS-E.
    I have 288 songs on the card and one m3u file that contains all the songs. On the PC the m3u shows all the songs. On the RNS-E the playlist only shows the first 99!! I tried again with another set of songs and the same.
    Is this normal?
    Appologies if this has been covered I try to search.
    Thanks.
  2. Re: SD cards m3u 99 songs?
    Dec 2007
    Bedford
    There is a way to show all the song but I dont know how as I dont have the MMI unit.
    Hopefully Ben will be around soon as he knows
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  3. Re: SD cards m3u 99 songs?
    Jul 2007
    Bucks, UK
    Is there away to have more than 99 in a playlist?
    Or do I have to figure another way to organize my tune?
    Just GOT : Audi A4 (B7) Avant S- Line 2.0 TDI (170) SE (still gettig used to the diesel, . . it's different)
    Just GONE : Seat Leon Cupra 1.8T (180), Silver (I do miss it).
  4. Re: SD cards m3u 99 songs?
    Jul 2007
    Bucks, UK
    Just to try and summarise this thread . . . . . .you may find bits or all of this useful, you may not . . . . .
    What I wanted to be able to do was access Albums / Artists and do a Random play for all songs on an SD card.
    I did have all my songs structured under Artists and Albums, then a M3U for all songs, as the M3Us seem limited to 99 songs this didn't really meet my needs . . . so here's the solution I can up with.
    There's two bits to this
    1. Getting the songs on SD card
    2. Creating M3U playlists
    1. Getting the songs on the SD Card.
    I have all my songs organized in Itunes and didn't want to change this. It also gives me the use of the Smart playlists to limit size of playlists by number of songs or X mb.
    I'm sure you can do similar things with other apps or even just copy the songs cards onto the SD card.
    So I created playlists in Itunes specifically for the RNS-E. I use smart playlists and limit the size to 1.83mb so they fit on the 2Gb SD Card.
    For example I have
    "5 Stars - Random" - Random selection of the songs I've rated 5 Stars.
    "Beatles, Stones, Kinks, Bowie etc". - Obvious
    " New Albums" - Albums I've added recently.
    I then use "Itunes Agent" to sync those playlist with specific SD cards in a flat structure. This creates new versions of the MP3 in the root of the SD Card, in the format "Artist - Title. mp3".
    Put the card into the RNS-E and you can find all your tunes in root of SD Card and find songs by Artist via the MP3 name or you hit mix!!
    2. Creating M3U playlists.
    After much digging around I found a couple of APPs call AutoM3U. I only managed to get one to work "AutoM3U V0.5 Beta by J Penneck"
    This will then create M3Us for All Artists, All albums and All Songs (don't need this now).
    So now I can access all songs on a SD card via the file structure and play Random if I want or I can access a particular artist via playlist.
    I'm glad I persevered on this as it great to use the controls of the RNS-E and have the songs on the big screen.
    This just what I found was good for me, Itunes agent will let you structure files in various different ways. So if you don't' want to play all your songs in random, you can use this to export Itunes playlist to an SD in a structure of \Artist\album\title. . . . .
  5. Re: SD cards m3u 99 songs?
    May 2010
    Hampshire (UK)
    I've got my songs on the SD card in folders:
    Dance.
    Pop.
    Rock.
    etc
    I can see the folders and can select songs within the folders, but when I select some of the songs via it automatically jumps to another song...it apperas to be totally random as well??
    Really gutted as I thought I'd cracked it with the mp3 tunes and SD Card. I'm 99% there, it's just annoying that it jumps to other songs.
    Anyone else come across this??
    Audi A4 Avant 2.0 TDi | S Line | 2006 | 140BHP | RNS-E | DIS | Cruise | Parrot Bluetooth | Sensors | De-Badged | Met Mauritius Blue
  6. Re: SD cards m3u 99 songs?
    Yateley, Hampshire
    Hi there! Is the card formatted as FAT or FAT32? I had some problems with a card and once re formatted as FAT32 it was fine. Might be worth a try.
  7. Re: SD cards m3u 99 songs?
    Jul 2009
    Warwickshire
    Hi All,
    I'm a software developer, and I've been writing a utility that reads the playlists out of your iTunes library and can then put them on an SD Card so that the RNS-E can read them.
    I've also come across the 99 song playlist limit as well, and I don't see a way around that.
    However, my utility can take a playlist which has, say, 150 songs in it - and then create two playlists - one with 99 in and another with 51 in. If that makes sense.
    I am still testing but hope to make it available reasonably soon. Will let the forum know.
  8. Re: SD cards m3u 99 songs?
    May 2010
    Hampshire (UK)
    Quote Originally Posted by El Guapo View Post
    Thanks...I'll whip it out and check it. It was a 2GB card a took from my digi SLR to test, so it may only be FAT.
    I'll let you know if it works.
  9. Re: SD cards m3u 99 songs?
    May 2010
    Hampshire (UK)
    Quote Originally Posted by Codestud View Post
    Hi All,
    Sounds good...keep us updated.
  10. Re: SD cards m3u 99 songs?
    Yateley, Hampshire
    I have over 150 songs in one folder and over 300 in total on the card.
  1. Has anyone removed their front door cards?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2010, 11:39 PM
  2. SD cards on 510 head unit
    By maisbitt in forum Scirocco - 2008-
    Last Post: 20-12-2009, 10:47 PM
  3. Question SD Cards
    By macallan3956 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-10-2009, 03:25 PM
  4. SD cards to use in Audi A4 DVD Sat Nav
    By IainP in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2008, 02:24 PM
  5. Bora TDI door cards
    By redtony in forum Bora - 1998 - 2005
    Last Post: 21-11-2007, 08:36 PM
