Thread: help with changing rear brake pads and discs
  1. help with changing rear brake pads and discs
    May 2009
    Penrith, England
    help im changing the rear pads and discs on my 97 audi a4 and cant get the piston to retract, ive got a retraction tool but the piston will not budge, any tips
  2. Re: help with changing rear brake pads and discs
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I dont know how your particular retractor works,but you need to push the piston while turning.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: help with changing rear brake pads and discs
    May 2009
    Penrith, England
    My retractor tool pushes and twists at the same time £20 from halfords, how hard should the piston be it wont budge an inch
  4. Re: help with changing rear brake pads and discs
    Apr 2010
    wales
    its the oil presure preventing the cylinder from being pushed right in, dont undo the top of oil resoir or you''ll end up with the brake fluid over the engine,,,
    what i did on my 1999 b5 is using a small G'clamp to squese the flexi brake pipe (rubber) to stop the flow of oil,, then undo where the brake pipe goes onto brake housing then you will find the plunger retracts well easy (only a few drops of oil from cylinder absorbe with rag),,
    fit brakes, get clips in right place, conect brake pipe, bleed brakes,
    make sure you note in which order the bearings and seals came out of the new disc and refit with greese,
    also not forgeting the ABS ring (with slots) otherwise you'll never get the ABS working
    vola,,,
  5. Re: help with changing rear brake pads and discs
    i had this problem, piston was seized and broke the retraction tool. had to get a new caliper, £75
    i was told it had probs been seized for ages, then i realized that when i was parked on a hill the handbrake wasnt as solid as it should be as only 1 brake was actually working. have you noticed this
  6. Re: help with changing rear brake pads and discs
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    It is important to keep the pressure on the piston whilst the piston is rotated. Try to increase the the pressure without going overboard.
    If this doesn't work then I'm afraid it sounds like a new caliper. Check with VAG dealer when checking prices as they have reduced prices somewhat & their price will be for new calipers rather than questionable "re-con" ones.
    Skoda Octavia II SE 1.9PD TDI
  1. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  2. Fixed Price Servicing - a good deal?
    By bozal in forum Golf MK6 - 2009 - 2013
    Last Post: 09-03-2010, 04:56 PM
  3. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  4. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  5. Changing front brake pads and discs
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-01-2008, 10:39 PM
