Thread: Poor Performance
Results 1 to 9 of 9
  1. Poor Performance
    Mar 2007
    2001 Passat 1.9 TDi 130
    Cars been a bit sluggish for some time now and performs poorly at lower revs.
    At stand still when revving up to around the 2000 mark there seems to be quite a delay between pressing the accelerator and the engine revving. It appears to be very unresponsive.
    When driving, the car is poor until the 2000-2500 mark at which point the performance is back.
    Its very noticeable when trying to pull away quickly, the engine lacks power until backed up by the turbo.
    No faults found on the diagnostics check, cars been serviced (Note: problem was pre-service). Only real problem since new was that one of the turbo cooler pipes was loose giving extremely poor performance and took some finding' I'm not sure if this has had any lasting effect on any of the other components.
    I've been using a diesel additive for a couple of months to see if this will have any effect on this fault but no real improvement to date. Cars done 80,000 miles and somebody did mention to me that the injectors can act up around 100,000.
    Cleaned air mass meter (non-evasive) by spraying solveen onto the sensor surface, no difference noticed.
    Any ideas!
    Feb 2007
    Newcastle upon tyne
    Try unplugging the MAF and drive the car. If the problem has gone your MAF is faulty.
  3. Re: Poor Performance
    fahad Guest
    hi people i have the same problem with my passat tdi pd 115 pd sport auto/trip there are 5 things to check on :
    • air flow meter
    • turbo
    • the pipes
    • egr vales
    • intercooler
  4. Re: Poor Performance
    Aug 2007
    South Hams, Devon
    I would say one of the turbo/intercooler pipes is collapsing, delaminating or split.
    You may be lucky & see which one it is without having to take them all off to check
  5. Re: Poor Performance
    fahad Guest
    hi look everyone i took it to vw delaers they only said to me that it will only be the turbo that is the thing thats dissterbing you.
  6. Re: Poor Performance
    Aug 2007
    South Hams, Devon
    Quote Originally Posted by fahad View Post
    Probably because they want to sell you a new turbo at £££'s take it to a garage that wants to diagnose the problem properly rather than randomly changing bits at your expense
    1999 VW Passat 1.9 Tdi Sport 110Bhp Bio-fuel
    Land Rover 110 200Tdi CSW Bio-fuel
    RRC 3.5EFI...Toy
  7. Re: Poor Performance
    Aug 2007
    Cornwall
    I had the same problem when I bought my car and it was the air mass meter, took it to VW and they charged me about £250, I mean even **** Turpin wore a mask, but then again, atleast they fitted it correctly, something I wouldnt have been so confident in doing myself.
    Pod
  8. Re: Poor Performance
    Hi Foxclub,
    I have the same issue on my VW Passat 1.9 tdi. Please see my thread:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=28059
    I'm wondering if you cured your problem and if you did, what you did?
    I have read much today about MAFS, sensors, N75 thingys, turbos and i don't really know where to start!
    Any help gratefully accepted......
  9. Re: Poor Performance
    fahad Guest
    HI i took it this time to the vw delares for a vag scan they said to me that it came up with a gearbox fult in a automatic triptronic.
    the vag scan was £40.00 they wanted to take the car for 2/3 days to fix the gearbox. total came up to £500/£2000 this is no jock. i will never go for vw again this is commen porblems.
  1. Poor Performance Passat PD 115
    By AlanP in forum Passat - Archive Topics
    Last Post: 29-08-2007, 04:49 PM
  2. Better performance, better economy
    By frakkafield in forum Archive posts
    Last Post: 28-02-2007, 05:45 PM
  3. passat poor performance 1.8 T
    By bromine in forum Passat - Archive Topics
    Last Post: 07-11-2006, 07:00 PM
  4. Getting more performance
    By johnlund in forum Passat - Archive Topics
    Last Post: 23-09-2006, 08:15 AM
