Thread: sharan drivers window
  1. sharan drivers window
    Mar 2010
    ellesmere port
    Hi there, just bought a '05 54 plate VW Sharan SE 130bhp TDi but the drivers window has stopped working. When you try to work the window, the hazards flash on the dash, bit wierd to be honest but does anyone know how to fix it? Thanks
  2. Re: sharan drivers window
    Apr 2010
    North Wales
    Quote Originally Posted by bangers2u View Post
    Hi, I have exactly the same problem with a 2005 05 plate Sharan SE 130 TDi, just joined this forum to see if there's an answer.
    In addition to that driver's window operating the hazards (single flash) the driver's side door central locking does not work or is very sluggish as is the fuel cover lock, all other locks operate correctly. At present I cannot lock the driver's door using the key fob, it works OK using the key in the door method. The passenger side electric door mirror has also stopped working.
    I have a code reader, which i plugged in and it gives me the following codes :-
    01142 Central Locking - Unlocking Motor
    01143 Central Locking - Opening Motor
    01148 Save Fuse Door (driver door deadbolt) - Activation
    01149 Save Fuse Door (driver door deadbolt) - Deactivating
    Any help would be much appreciated.
  3. Smile Re: sharan drivers window
    Apr 2010
    North Wales
    OK found the problem...........
    After reading a bit more on these forums I decided to check the wiring loom between the door and the pillar by peeling the rubber gaiter back (away from the door), sure enought there wer two severed wires and another four with cracked insulation.
    Removed the loom plug by rotatinfg the ring anti clockwise and crimped the two broken cables. Plugged the loom back in and all OK.
    Will repair the others when I have time.
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. Drivers Window Switch - Anyone had issues??
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2009, 01:01 PM
  3. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
  4. Dare I ask Sharan drivers for help with my Galaxy??
    By bodgerd in forum Touran - Sharan - Caravelle
    Last Post: 07-05-2007, 04:14 PM
  5. drivers side electric window fault
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2007, 04:22 PM
