Thread: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
  1. Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Mar 2010
    Colchester, UK
    Hi guys - this is my first post and as an inexperienced Audi owner, I was hoping someone could help me!
    Recently, I bought a 1997 Audi A4 Avant 1.9 TDI SE Auto - and I'm absolutely loving it so far - cannot believe I've not had an Audi before.
    There is 1 small problem I've been experiencing though relating to the immobiliser. Basically, I insert the key and turn the ignition on and the glow plug and immobiliser lights appear. I wait for them to both go out and most times, it's all fine, they go out and I start the car.
    However sometimes after the lights go out, the immobiliser light just flashes and the immobiliser is still activated and I can't start the car for more than 2 seconds. I take the key out and hear the 3 little bleeps which I believe mean the immobiliser is active and then try again - sometimes it's fine straightway - the most attempts its taken so far is 6. It has always been getting there in the end and I appreciate in the grand scheme of things, it's a tiny issue but obviously I'd love to get it sorted to get my car perfect.
    I've tried a spare key but that doesn't seem to make a lot of difference.
    Does anyone have any ideas? Anyone experienced this before and solved the issue? Any help would be greatly appreciated!
    Thanks so much
    Andy
  2. Re: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Jan 2009
    towcester northants
    sounds like a reader coil fault
    remove steering column covers and remove the connector to the reader coil
    seperate connector and tighten the terminals in block
  3. Re: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Feb 2010
    Derbyshire uk
    Be aware that airbag's are dangerous........
    Remove the battery termanels before starting work...
  4. Re: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Oct 2009
    Redcar
    what if the below doesn't work? i've tried this and my light will flash for ages, i keep turning the key, and it takes ages for it to work
  5. Re: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Possibly Low Signal from the Key ? Have you tried using your spare for a while to compare?
    As mentioned the reader Coil could also be suspect.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Audi A4 Avant 1.9 TDI - Intermittant Immobiliser Issue?
    Oct 2009
    Redcar
    the only spare i got was one that was cut at a shop, so no immobiliser chip in it.
    would vagcom pick up the fault do you think??
  1. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  2. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  3. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  4. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  5. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
