Thread: Alarm annoying whole street
  1. Alarm annoying whole street
    Jan 2009
    Hi everyone.
    Recently my passat TDI estate has had its alarm going off. It seems most often to hgappen during the early hours which is a real pain. Does anyone have any ideas as to why this might happen. I checked the boot and it is shut properly. Could it be a sensor problem elsewhere? Can I completely disable the alarm?
    Thanks guys
    Dean
  2. Re: Alarm annoying whole street
    Norfolk
    A code read should help identify what is triggering the alarm Check for wet/damaged wiring to the ccm under passenger carpet. You can disconnect the sounder under the bonnet...That will shut it up.
  3. Re: Alarm annoying whole street
    Jan 2009
    Thank a lot I'll take a look
  4. Re: Alarm annoying whole street
    Jul 2008
    Check the plenum to see if you have a little pond and the drain plug issue.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=92813
  5. Re: Alarm annoying whole street
    Aug 2007
    Might also be a leaky rear screen washer pump - the water leaks down the inside of the tailgate and messes up the sensor which checks the tailgate is shut properly. There is a repair kit, but a whole new unit is not much more and is easy to fit.
  6. Re: Alarm annoying whole street
    Apr 2009
    Leicester
    Most likely a leaky rear washer jet. Had this issue myself, bought the repair kit from VW and it was easy to sort.
    As for the above, it is very easy to replace the parts from the kit. Why spend an extra £50 on a new wiper motor?
  1. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  2. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  3. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  4. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  5. Alarm is annoying me.
    By daniel graham in forum Audi A3 - Archive Topics
    Last Post: 03-07-2007, 09:56 AM
