Thread: Water / Condensation - Avant Rear Light Cluster
Results 1 to 9 of 9
  1. Water / Condensation - Avant Rear Light Cluster
    Anyone had this problem?
    Had the car for just under a year now and either I've only just noticed it (unlikely) or it's just happened. Water droplets visible, so not your standard bit of mist in there. My local dealer thinks the seals have gone; which surprise, surprise aren't covered under warranty
    Cheers all,
    Ed.
    B7 A4 Avant S-Line pearlescent Dolphin Grey. Factory fitted: Leather interior, MFSW, storage pack, isofix, folding mirrors, bluetooth, rear PDC, rear blinds. Retrofitted: DIS* and washer bottle sensor, cruise control*, RNS-E* (inc SDS), 'S' badge, front interior ambient light, rear map lights with ambient lighting. To do list: RS4 handbrake grip/gear knob/pedals/ARB, colour DIS. * by Shark_90
  2. Re: Water / Condensation - Avant Rear Light Cluster
    Jul 2007
    Bucks, UK
    Hi, I have this on my 2007 A4 Avant S-Line SE.
    I've only had it a couple of weeks and still has warranty on it until Oct. I have it booked in at Audi for Saturday to take a look at this and a rattly door handle.
    They said they would dry them out and see how it goes, but my point is How did the water get in there first place?
    I'll let you what they say.
  3. Re: Water / Condensation - Avant Rear Light Cluster
    Much appreciated. I'll be taking them out over the weekend to inspect for myself...
  4. Re: Water / Condensation - Avant Rear Light Cluster
    At a loose end tonight so though I'd have a shufty. A doddle to remove following the instructions in the manual. Once out,I removed the bulb holder, dried the inside with a hairdryer, removed and cleaned the seals and housing, reassembled and finally refitted.
    All look fine to me. The only seal is that between the bulb holder and the cluster and they don't seem too bad. The main cluster is one-piece moulded so I can't see any chance of water ingress there. Hopefully that sorts it; if not, I'll look into replacing the seals.
  5. Re: Water / Condensation - Avant Rear Light Cluster
    Jul 2007
    Bucks, UK
    Thanks for the update, I think I'll end up doing the same.
    They fixed the door handle no problem, they didn't even take the lights out!!! They used the term "feature" a lot then said they couldn't do anything under Warranty and even if they did put new lights in would happen again!!
    I also mentioned poor MPG, again bit of a fob off, but I didn't push this too much as I've only had the car a few weeks. I need to do some research on this. If anyone reads this and has had the ECU updated to fix poor MPG then any info would be much appreciated. They again denied any knowledge of such update.
    I've never been that impresed with Audi in Aylesbury when I was looking to buy a car and with my brief encounters with the service department, maybe I'll try Amershan or MK next!!
  6. Re: Water / Condensation - Avant Rear Light Cluster
    Apr 2009
    Larbert Scotland
    I had the same problem with condensation / water in my rear light cluster. I carefully removed the lights which did come out with a bit of patience however on examining the light unit I found a crack along the seam where the red lens meets the grey back. I can only think that the last owner wasn't as patient when removing the light and has tried to force out the light causing it to crack. I put clear silicone round the light and this appears to have sorted the problem without forking out for a new unit
    Andy Avant
    2.0 ltr TDI 140 S-Line Avant
  7. Re: Water / Condensation - Avant Rear Light Cluster
    Thanks for that. I'll see how they fare and if no better it'll be silicone at the ready. I'm sure I'll regret saying this, but they're fine so far.
  8. Re: Water / Condensation - Avant Rear Light Cluster
    Jul 2007
    Bucks, UK
    I also pulled my tail lights out the other night, dried them out with the Wife hair dryer. Like Avant Andy I found a previous owner or dealer had not been as careful and had to seal one of the units up.
    But now all dry and sealed . . . . . . had the car washed yesterday and all seems good.
    Just GOT : Audi A4 (B7) Avant S- Line 2.0 TDI (170) SE (still gettig used to the diesel, . . it's different)
    Just GONE : Seat Leon Cupra 1.8T (180), Silver (I do miss it).
  9. Re: Water / Condensation - Avant Rear Light Cluster
    Dec 2006
    NE Fife
    Another example of this - on my 2007 B7 Avant - sounds like it is a common issue.... There is misting in the clear lens on the passenger side rear lens. The car is still under Audi warranty so I'll ask and see what they say.
    If they will not fix it, I will inspect the unit as advised on this thread.
    Thanks for the info,
    Regards,
    Bob
  1. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Rear light cluster cost?
    By clonmult in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2010, 07:52 PM
  4. Please Help Replacement of rear light bulb. Audi A4 Avant
    By RoyD in forum New Member Introductions
    Last Post: 04-04-2009, 03:16 PM
  5. How does the Quattro system work?
