Thread: A6 2.7t engine and hvac. a few codes from vcds
  1. A6 2.7t engine and hvac. a few codes from vcds
    jontawn Guest
    Hi there,
    I had a look at my mates A6 today as he said it didn't seem as powerful as normal and a bit 'under the weather'.
    A quick scan of the car revealed an intermittently faulty N75 valve:
    17956 - Boost Pressure Regulation Valve (N75): Open Circuit
    P1548 - 35-10 - - - Intermittent
    And we also got this one too:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    41-10 - Blocked or No Voltage - Intermittent
    I have more details from the scan should they be of any use?
    My intentions were to unplug the N75 valve, ensure all connections are clean and tidy, check all the vacuum lines to/fro the valve and make sure they're all clean/not cracked.
    The HVAC motor, seems as though when we turn up the temp inside all is ok and when its turned right down it seems ok too, but the bit in the middle. So this fault would explain things, but where on earth is this motor located and how difficult is it to swap it out?
    Cheers,
    JT
  2. Re: A6 2.7t engine and hvac. a few codes from vcds
    Engine code, model and year pleas. The engine code is on the ID label in the spare wheel bay. Regards Peter
  3. Re: A6 2.7t engine and hvac. a few codes from vcds
    Aug 2007
    Wicklow
    The air-con flap one, I have been told, is really common and to not even bother to try and repair as it's a massive job for very little reward.
  4. Re: A6 2.7t engine and hvac. a few codes from vcds
    You have to remove the storage unit from the drivers side under the sterring column then the entire centre section of the dash panel and the reinforcement bracket. Then you can gain access and change the faulty flap motor. It is quite a big job. Regards Peter
  1. login codes needed for new abs pump coding
    By deutsch in forum VCDS - Help Requests
    Last Post: 07-04-2019, 05:18 PM
  2. Audi A6 2006 SE 2.7 flashing yellow coil, can go above 300rpm inc VAGCOM data
    By blackpenny15 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-06-2015, 08:35 PM
  3. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  4. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  5. A6 (C5) fault scan
    By kite in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-11-2009, 03:28 AM
