Thread: idling problem
  1. idling problem
    frank mellin Guest
    I have a 1999 passat 1800 with 64,000 genuine miles.Auto.
    It developed a fault when idling with the revcounter swinging between 500-1500rpm.Garage have cleaned the throttle body and checked everything possible.Nothing coming up on diagnostics.Car runs beautifully but when slowing to a stop the revs still drop back to below 500rpm which results in the anti stall device kicking in .this then causes fluctuations in idle speed which for an auto is bad news!!
    Surely someone has the answer................please
  2. Re: idling problem
    Jul 2008
    Has the garage (really) checked:
    All vacuum pipes - all the 3mm ones esp' at hose junctions and all other intake hose junctions for leaks. Intake pipes for blockages. Replace the vac lines with silicone pipe. A vac leak will cause your problem.
    MAF fault? Unplug to see if there is a difference.
    Coil packs - known 1.8 fault - usually on later models so I've read.
    All the above will cause rough idle/dipping although my money will be on a vac leak somewhere..
  1. Climate control - electrical problem - help needed!
    By JohnHighfield in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2010, 09:17 PM
  2. idling problem on mkvi Golf gti
    By michaelhannigan in forum Golf MK6 - 2009 - 2013
    Last Post: 07-02-2010, 06:27 PM
  3. idling problem with A6 Avnte 2.6 A/T
    By lappies in forum Chat - Anything with wheels
    Last Post: 22-11-2007, 08:15 PM
  4. A4 1.8t 1996 P reg idling problem
    By mikeyg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2007, 06:11 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
