Thread: noise when steering
Results 1 to 10 of 11
  1. noise when steering
    Feb 2010
    england
    My audi s3 makes a donking noise when steering any suggestion to what it is thanx
  2. Re: noise when steering
    Mar 2009
    Hi, have you looked at your upper strut mounts/bearings? is it when your at a stand still or moving?
  3. Re: noise when steering
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    As above and also check lower wishbone bushes
  4. Re: noise when steering
    Feb 2010
    england
    Thanx for ur help il look asap!
  5. Re: noise when steering
    Donegal, Ireland
    I recently had this problem with my A3 it was making a noise when steering both while moving and at idle it was simply low power steering fluid however the fluid kept dropping slowly, I ended up having to replace the steering rack
  6. Re: noise when steering
    Feb 2010
    england
    Was that an expensive job?
  7. Re: noise when steering
    Donegal, Ireland
    I managed to get a second hand steering rack for 250 but the labour still cost another 200 at an independent garage so the total cost was 450
  8. Re: noise when steering
    Feb 2010
    england
    well i hope its not that il ave to get it checked appreciate your help
  9. Re: noise when steering
    Aug 2009
    coventry birmingham
    Quote Originally Posted by Bens38l View Post
    Mate i had a similar problem i had whining, moaning and groaning coming from the steering evertime i touched, was getting for a expensive repiard until my mate suggested i check the power steering fluid, topped it up and its like new, hope this is all that is with ur car
  10. Re: noise when steering
    Feb 2010
    england
    well ive checked that seems ok its more of a knock like the spring twisting and all of a sudden it knocks but thanks for ur imput.
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  4. Question Power steering groan/grinding noise
    By drivergolfmk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-11-2009, 12:22 AM
  5. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
