Thread: Hissing from throttle body?
  1. Exclamation Hissing from throttle body?
    Apr 2010
    United Kingdom
    After having three breather pipes replaced (cost £120 parts only, ouch!) on my 2.0 petrol passat. I am now getting a hissing noise from behind the intake manifold on a fast kick of the accelerator, which I've located coming from the throttle body. All the pipes in this area are leak free.
    I'm pretty sure there was no hissing before, is this normal as the old breather pipes were badly split, the intake manifold also had to be removed (its plastic not aluminium -rubbish) to fit one of the breather pipes. Any advice on this problem would be greatly appreciated.
  2. Re: Hissing from throttle body?
    Apr 2010
    United Kingdom
    The garage that fitted the breather pipework checked for leaks visually and with spraying brake cleaner, no change to the engine idle, so he said there isn't any leaks. But today I noticed that when slowing down, changing into neutral gear the engine idle sat at 1100 rpm for 10-15 seconds before going to normal idle position. Since the pipework was replaced the mpg values on the dash have also became erratic. Again I may be getting paranoid as I had a nightmare with my previous car.
  1. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  2. Question Audi A3 S reg. 1.6 Erratic iddle and poor starting, Throttle Body? or ?
    By win2kpro in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-04-2010, 11:11 AM
  3. Throttle Body Allignment
    By markf497 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-02-2010, 07:07 PM
  4. Throttle Body Conversion HELP NEEDED!!!
    By gtxi in forum South West England
    Last Post: 18-12-2009, 08:06 PM
  5. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
