Thread: Rear door locked shut. How do I open ?
Results 1 to 10 of 13
  1. Rear door locked shut. How do I open ?
    mal_t Guest
    1999 Passat saloon.
    Central locking appears OK, but door handle on outside or inside or rear door dont work so I cannot open the door.
    I have taken the door card off to expose inner panel. I have removed all bolts on inner panel but it wont come off. The window winder and I think door lock are stopping it. I think I know how to remove the window winder, but even if I do that I think it will still be stuck to the door lock - is this so ?
    Is there any way that the door lock can be opened by triggering the mechanism from where I am at the moment ? Else what can I do ? What would a garage do in this situation ? I am so so so frustrated .....
    Many Thanks,
    Malcolm
  2. Re: Rear door locked shut. How do I open ?
    The lock is still attached to the door,depending which door it is ,but look to the top rear of the plate,you will see 2 black plastic plugs you need to punch these in,In the center of the plate there is a rubber plug,remove it and you can access the fixture which fits the window to the Window lifter
  3. Re: Rear door locked shut. How do I open ?
    mal_t Guest
    Got the door open by pulling the internal cord and pushing the door whilst repeatedly locking/unlocking with the remote key fob.
    Sprayed with WD40 and white litium grease and its working OK now.
    Only trouble is the external handle is not lying correctly - I have pulled something out when trying to open the door from the outside I guess !
  4. Re: Rear door locked shut. How do I open ?
    You have pulled the cable out of the handle,you will need to remove the plastic cover and then the housing to access the cable
  5. Re: Rear door locked shut. How do I open ?
    mal_t Guest
    Kenny,
    Thank you for the help - much appreciated
    When you say 'remove the plastic cover' - is that on the door handle ? If so is it removed by flicking it off with a screw driver or something ? And will the handle then just come out - and it be obvious how the cable fits in ?
    Thanks again,
    Malcolm
  6. Re: Rear door locked shut. How do I open ?
    http://www.taligentx.com/passat/main...lockmechanism/ look at 15 - 18 although this is the front door the rear door is the same except for the locking barrel.Note Do not screw the torx screw out more than necessary to remove the housing,and keep the handle pulled out through out the complete operation.
  7. Re: Rear door locked shut. How do I open ?
    mal_t Guest
    Had a look ....
    On the rear door there is no Torx bolt holding in the lock (I can see it on the front door). So I cant understand how I can get the lever out to expose where the wire clips in ?
    Thanks,
    Malcolm
  8. Re: Rear door locked shut. How do I open ?
    Norfolk
    Pull out the bung in the door. Torx bolt is inside on the lock housing. Unscrew with torx screwdriver.
  9. Re: Rear door locked shut. How do I open ?
    mal_t Guest
    Thanks for the help guys
    Its possibly just me - but I cannot find the plug in the end of the door to remove. See the following photo:
    http://s595.photobucket.com/albums/t...t=IMG_0392.jpg
    The door handle is shown in the following photo:
    http://s595.photobucket.com/albums/t...t=IMG_0393.jpg
    Can anyone confirm how this door handle can be removed/fixed ?
    Many Thanks,
    Malcolm
  10. Re: Rear door locked shut. How do I open ?
    it's behind the seal
  1. Rear door locked and wont open!!!!!
    By mickd in forum Early Passat Forum - Pre 97
    Last Post: 23-08-2009, 04:30 PM
  2. Question How to open stuck Polo rear door
    By 00ian in forum Polo - Derby - Lupo - Fox
    Last Post: 12-07-2009, 12:39 PM
  3. Cant open rear boot
    By shezz07 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-07-2009, 07:38 PM
  4. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  5. Can't open rear door
    By tonycooling in forum Bora - 1998 - 2005
    Last Post: 24-02-2008, 07:48 PM
