Thread: Audi a6 avant tdi - electrical gremlins
  1. Audi a6 avant tdi - electrical gremlins
    Dec 2009
    windygates, ecosse
    Hi All,
    My car has developed a problem where the car will fire up no probs and run but you have no
    indicators
    blowers
    wipers
    headlights....
    I put the car into a garage 3 months ago and they diagnosed a faulty igniton relay - but the same prob has come back today , all help welcome
    Thanks Gary....
  2. Re: Audi a6 avant tdi - electrical gremlins
    Oct 2007
    X contact relief relay position 2 on relay carrier
  3. Re: Audi a6 avant tdi - electrical gremlins
    Dec 2009
    windygates, ecosse
    that sound promising - can you tell me where I can find this relay and what it looks like ?
    Thanks in advance Gary...
    PS. It is a 2003 model
  4. Re: Audi a6 avant tdi - electrical gremlins
    Jun 2007
    Position 2 in the relay carrier behind the drivers side storage compartment. Regards Peter
  5. Re: Audi a6 avant tdi - electrical gremlins
    Dec 2009
    windygates, ecosse
    Found the relay - it is not genuine VAG but some italian make, it was also hot to the touch.
    When I went out to repair my leaking rear washer everything worked fine... switched off ignition to look at relay - when I re-inserted relay everyhting stopped working again.
    However when you put the ignition key to positon 2 everything will come on and work but when you crank it over and start it you lose everyhting again...
    Can somebody supply me with a VAG no: for the relay and I will try genuine 1st if not that then I think I will need to look at the switch ?
    Thanks Gary...
  6. Re: Audi a6 avant tdi - electrical gremlins
    Dec 2009
    windygates, ecosse
    have ordered a new VAG relay and ignition switch - can anyone tell me if there are any procedures for getting to the igniton switch ? the 1 main piece of advice I have been given is to disconnect the battery for 20mins before removing airbag and also make sure it is not lying on its face...
    thanks in advance Gary........
  1. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  2. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. The new Audi Q5: Sporty and versatile
    Last Post: 19-04-2008, 02:25 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
