Thread: A4 Alarm.
Results 1 to 9 of 9
Hybrid View
  1. A4 Alarm.
    May 2007
    Wrexham
    I'm new to all this so please bear with me. I have read various threads on faulty alarm systems on the A4. I have a 1998 A4 tdi saloon and the alarm has started going off at random intervals. I have checked the o/s of the boot and only found the central locking pump, the alarm horn/siren is on the n/s on its own. I cant see any battery back that has been mentioned unless the battery is actually in the horn itself ? I have also turned the internal sensors off but it still goes off.
    Can anyone help with this problem before I take to the car with a big stick
    Woz
    Oct 2005
    Lutterworth
    VAGCOM will tell you what the alarm source is.
    Or take it to the dealer and have him check it for 1/2 hours labour.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    May 2007
    I have the same problem on my 2000 A4 saloon, any idea where this battery pack is.Is it possible that it is in the siren itself?
  4. Smile Re: A4 Alarm.
    Dec 2006
    kallie a4 .don't know if you found out but the alarm battrey is located in the siren in the off side of the boot.it's a plug in module,approx £80 from an audi dealer.remove trim from across boot and remove off side panel.the unit is then located in a well below the rear lights.best of luck
  5. Re: A4 Alarm.
    Jul 2008
    Hello all! i'm a newbie i'm afraid but have a little expreience in the trade for all the good it's done me! (audi "trade rates" are non-existent!!!) We seem to be singing from the same hymn sheet here! our "w" plate a4 is serenading us at all times during the night and also occasionally when we drive it! the persistent "casio watch" beeping eminating from the boot is becoming annoying now! i was told that on the vw's there is a switch that kills the boot alarm by a mechanic but i can't find one on the audi anywhere!Sorely tempted to just buy the siren/battery combo and plug it in myself but am loath to pay out if it doesn't work! typically, i refuse to take it to main dealer to be diagnosed as am sure you chaps can help me out!if it is the problem, does anyone have the part number of the unit to hand? (i'm sure they are all the same as another thread says main dealers seem to carry stock as it's such a common problem!!!)Is this likely to be anything else other than the battery in the siren in the boot or could it well be something else altogether?many thanks for reading, PLEASE PLEASE PLEASE say it's going to work!!!!!Pred!
  6. Re: A4 Alarm.
    Southern County Softy
    20 Post(s)
    The alarm back up battery can be changed, heres a link to a fix on a TT
    Should be the same for any Audi with this alarm
    http://www.tt-forum.co.uk/forum/viewtopic.php?p=792942
    A4 2.5 tdi QS (mapped)
  7. Re: A4 Alarm.
    Dec 2006
    Quote Originally Posted by PRED View Post
    pred posted a reply may be under wrong name please check other names. whoops
  8. Re: A4 Alarm.
    Jul 2008
    Thanks for your help on this mary, i'll have a quick play over the weekend but have to wait til payday to get a new unit! bloody car's costing me a fortune!!! just bought a new n/s/f rear lower arm form my work for 45 quid, getting a guy to do it for 30 but it's chewed through two tyres already so i'm keen to get the thing fixed before it ruins me!!!
    i'll keep you posted mary on my progress!
    also thank you kite, i'd had a look at your pics/demo of how to do it but as it's the missus car, she's told me not to "fiddle" ie cutting bits off etc!!!! but i've kept the link just in case!! i'm still worried about the water in the footwell causing it but i know how to fix that problem too now after a convo at work!!!
    wish me luck all, i'll be in touch!!!
    ta!
    Pred
  9. Re: A4 Alarm.
    Dec 2006
    Quote Originally Posted by Woz View Post
    Woz
    hi pred, the alarm is on the off side in the boot,remove horizontal plastic trim which goes across boot.then remove offside trim panel,the alarm is down the bottom in the well of the car.simple plug in job. unit is around £80 from main dealer. you may have to modify bracket.maybe helpful to remove spare wheel before removing trims.my a4 (w) had same problem and i sorted it.any problems,get back to me ,i'll watch this space. i'm not an audi mechanic though. mary
  1. A4 Alarm
    By Jimbo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2007, 03:33 PM
  2. alarm a4
    By mary in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2007, 01:08 PM
  3. alarm
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2007, 12:42 PM
  4. SDI alarm
    By udders71 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-05-2007, 07:34 PM
  5. Alarm....
    By Niklock in forum Audi A3 - Archive Topics
    Last Post: 07-05-2007, 11:22 PM
