Thread: steering issues gti
Results 1 to 10 of 11
  1. steering issues gti
    Jan 2010
    norwich
    hello, help my mk3 gti pulls to the left, had new shocks,new top mounts and bearings,camber set at 1/2degree negative,new wishbones, new tie rods and track rod ends and new anti roll links, tracking has been done aswell, any ideas please? offside wheel does feel floaty but no play in any joints, argh!!!!!!!!
  2. Re: steering issues gti
    Jan 2009
    towcester northants
    swop tyres side to side if not rotational or front to back
    this will eliminate if its tyres
  3. Re: steering issues gti
    131 Post(s)
    1978 Post(s)
    If the alignment is perfect and the tyres are too, then there is not much you can do. Golf 2 and 3 are prone to pulling to the left.
  4. Re: steering issues gti
    Jan 2010
    norwich
    after looking around i have noticed the strut mount isnt sitting flush inside the housing in the wing, i am guessing this would put the caster setting out aswell, really need to find a better garage to do my repair work, hoping to get the strut off and fitted properly myself
  5. Re: steering issues gti
    131 Post(s)
    1978 Post(s)
    There must be a gap between the top plate and the housing turret, this closes up when the suspension is unloaded. I think it is impossible for the top mount rubber to not sit correctly in its location, it is self aligning. The caster is not adjustable, if it is out, something is bent, usually the wishbone.
  6. Re: steering issues gti
    Jan 2010
    norwich
    you would think so, definately not sitting flush in the plate, there is a big gap between the rubber mount and the plate, could get my finger between it.
  7. Re: steering issues gti
    131 Post(s)
    1978 Post(s)
    Completely normal and nothing to worry about, as you turn the steering to lock the plate will rotate and sit at an angle with an uneven gap.
  8. Re: steering issues gti
    Jan 2010
    norwich
    you are right,i am at a loss as what to try, garage only replaced the nearside shock, could the shock be causing the problem
  9. Re: steering issues gti
    Pembrokeshire
    22 Post(s)
    . they only replaced one shock. why??? shocks should always be replaced as a pair.
  10. Re: steering issues gti
    Jan 2010
    norwich
    think its definately time for a new mechanic, been and had a look and the ride height is lower on the offside, guessing this would contribute to my gti pulling to the left, i thought both had been replaced,, appreciate the information you guys have posted to me
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  3. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  4. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 13-06-2009, 04:20 PM
  5. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 20-05-2009, 09:45 PM
