Thread: what sd card for sat nav plus ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. what sd card for sat nav plus ?
    Dec 2009
    bristol uk
    guys
    i have a audi A4 2.0tfsi s line special edition with the sat nav plus
    it has the 2x sd card reader under the screen ,and i would like to fill this with sounds :-)
    but reading other forums people are saying max 4gb in each slot and only some brands work ? and also it has to be SD not SDHC ?
    can someone give me some pointers on what brand to buy and size ect ect and maybe a link to where they bought theres from :-)
    2x 4gigs would be good as thats alot of sounds :-)
    any info would be great
  2. Re: what sd card for sat nav plus ?
    Southern County Softy
    20 Post(s)
    And a file limit of 512..........
    A4 2.5 tdi QS (mapped)
  3. Re: what sd card for sat nav plus ?
    Dec 2009
    bristol uk
    so any 4gb sd card ?
    but deffo not sdhc ?
    come on guys need some buying advice :-)
  4. Re: what sd card for sat nav plus ?
    20 Post(s)
    I'm not sure that 4gig will work...
  5. Re: what sd card for sat nav plus ?
    Aug 2009
    Near Lanark
    21 Post(s)
    Trapster
    SDHC will not work and with a file limit of 512 there is little point in buying 4gb cards. 4gb non hc cards do exist - try searching Transcend on Amazon - but I'm not sure the extra capacity is worth it unless you plan on filling the card with long tracks 10mins long each.
    I'd go for normal 2gb sd cards. You can pick them up in numerous places for a few pounds each. Don't bother too much about getting fast cards unless you intend to use them on your camera too. Normal speed cards work perfectly well.
    I'd try 7dayshop.com first - they're normally among the cheapest place to get them.
  6. Re: what sd card for sat nav plus ?
    Dec 2009
    bristol uk
    thanks for the info
    so if i get 2 x 2gig cards
    but i guess i can put 512 songs on each card max ? is that correct
  7. Re: what sd card for sat nav plus ?
    Aug 2009
    Near Lanark
    21 Post(s)
    Exactly.
    You can have folders within folders no problem but still limited to 512 files per card unfortunately.
    Where are you?
    Might be worth meeting up with an existing member so you can see it in action.
    I'm near Glasgow if it's any good
  8. Re: what sd card for sat nav plus ?
    Dec 2009
    bristol uk
    hi thanks for the offer but i am in bristol ;-) bit far to go
    but have tried a 32meg card and put 3 tracks on there and worked first time no problem.
    so i have on order 2x 2 gig cards from play
    so i guess i can get 1024 songs on the 2 cards
    i think that should be enuf ;-)
    thanks for all the input guys
  9. Re: what sd card for sat nav plus ?
    Jan 2010
    Rossendale
    i have used 2 x 2gb standstand SD cards NOT SD and both of these work fine. At 1st i thought OMG 2gb i have a MP3 player for running and thats 16gb lol. But i can cram loads and loads of songs and leave them in the folders and the player sees them! I have 2 cards so if i take one in the house and forget i always have the other one in!
    Its a pain running the sat nax from Disc tho!!
  10. Re: what sd card for sat nav plus ?
    Yateley, Hampshire
    Also I had a problem with one of my cards and it worked fine on PC and Blackberry but not in the car. Had to re format it as FAT32 not FAT in the end for it to work.
  1. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  2. CREDIT CARD SCAM... Pls read..
    Last Post: 30-11-2007, 03:08 PM
  3. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  4. Anyone trading in a B6 Audi A4 with RNS-E Sat Nav ?
    By Johnboyc in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2007, 04:38 PM
  5. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
