Thread: A6 C6 VCDS Changes - Post & Pre Facelift
Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 168
  1. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #61
    46 Post(s)
    Its not the door module, its the mirror fitted.
    pot luck if you don't have memory.
  2. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #62
    Aug 2012
    Midlands
    Sorry another stupid question.. here goes, can you in VCDS make the DVD drive on my MMI 3G low... i think.... play normal DVD's on the screen.
  3. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #63
    46 Post(s)
    I think only the HDD version plays DVDs as you're using your drive for nav only iirc
  4. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #64
    Aug 2012
    Midlands
    I have been trying some vcds stuff that I found on another forum but its for a5's I think. You can change the DRL brightness in different situations, add a double disarm bleep but on the A6 I can seem to find this. Can you change the DRL functions?Cheers
  5. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #65
    46 Post(s)
    Have a look through the cent elec module and cent conv modules for coding as they vary between car due to different versions of the module being fitted.
  6. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #66
    Aug 2012
    Midlands
    No can't find anything on drl settings. I also can't get a boot up screen on the mmi. Think I have done everything I can
    Sent from my HTC One using Tapatalk
  7. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #67
    46 Post(s)
    Splash screen from google How to change startup screen in MMI 3G? | Audi Forum
    Post #12. Don't click anything you're unsure of.
  8. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #68
    Aug 2012
    Midlands
    Ahhh there are tick boxes in vcds but they didn't do anything
  9. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #69
    Aug 2012
    Midlands
    To be fair I only wanted to see what it would do... Don't think I will mess further. Cheers though
  10. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #70
    Jul 2013
    76 Post(s)
    Wanted to add this from inspectorman63 for a cure to erratic auto wipers.
    Quote Originally Posted by inspectorman63 View Post
    This is a me too post, but it also has the answer. Having driven my 2006 2.0 TFsi for six months, I too was unimpressed that the intermittent wipers were far too keen to go to maximum wiping and were too sensitive. I ended up never using positions 3 and 4, and rarely position 2. The wiki on the RossTech site is no help; it redirects to an A8 setting which cannot be input into an A6. So I asked them.
    After one suggestion which didn't work, they suggested setting the RLS (RegenLichtSensor) coding to 00077101. The setting I had was 00141886. The new setting has transformed the sensitivity of the intermittent wiping from very annoying to usable. Settings one to four now have a usable range of sensitivity, and full speed mad wiping is rarely initiated by the sensor. A great result from RossTech and another reason for buying the genuine gear rather than the moody knock-offs.
    This works very well.
    1 2 0
  1. Question Facelift interior into pre-facelift car 5-door
    By westiej in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-11-2014, 11:30 AM
  2. A6 C6 pre to post facelift rear diffuser swap
    By 692DPG in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-12-2013, 06:22 PM
  3. Thinking of a 2.0 tdi avant.. Pre Facelift or Facelift?? Difference of 4 Grand.
    By mrosd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-07-2012, 07:49 AM
  4. What mods available foe pre-facelift A6 C6 with VCDS?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2012, 09:57 PM
  5. Please Help Avant Facelift to Pre-Facelift Tailgate Swap
    By mixmaster_mike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2011, 11:55 AM
