Thread: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    May 2009
    Knaresborough UK
    Just wondering whether anybody who managed to get their xenon headlamps replaced by Audi due to the condensation issues have had any further problems, i.e. has the problem re-occurred. Just need some more ammunition to chuck at Audi as they are steadfastly refusing to sort my headlamps out.
    Tim
    09 A4 Avant 2.0 TDI S Line - Lava Grey, 19" Alloys, Sat nav, Storage pack, Folding mirrors, Hill hold, Interior light pack, Load system, AMI, Cruise, TPMS, B&O, Retro- Rear park sensors, Audi Winter wheel package.
  2. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Jun 2008
    Yep fixed for me, finally got the dealer to replace both units a few months ago with the updated parts.
    No issues since the switch.
  3. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Bratty Guest
    I think that once the dealership makes the desicion to relent and change them, then you need to make sure that they replace the units with modified ones (with the rubber bleed thing) but also carry out any other mods required like the pipes that connect to them.
    Perhaps A1exp can supply you with the part numbers off the new ones?
    I will have a look on my spare set of adaptive xenons (RHD UK Spec) for the part number on them.
    Dunk
    2 0 0
  4. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Bratty Guest
    UK Specification Modified lights as supplied on MY2010 cars from June 09.
    Xenon Headlight (Adaptive) R/H:- 8KO-941-030 H
    Xenon Headlight (Adaptive) L/H:- 8KO-941-029 H
    Dunk
  5. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Dec 2008
    Would you mind having a look at the upper part of both headlights and tell me which date is written there? I´m having problems with my already replaced headlights and would like to know that date
  6. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Dec 2008
    Yes, those parts mentioned are still the same ,from 2008 to 2011 as you see in this picture taken from Parts catalogue.The only hope is that manufacturing quality has changed and the new ones are improved units but with the same part number...
  7. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Jul 2008
    Perhaps of little consolation but my headlight unit changed circa 18 months ago pre-breather tube model has stayed octopuss free.
  8. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Bratty Guest
    The date on them is 02.04.09 they were manufactured by "Automotive Lighting" but supplied as original parts by Audi UK.
    The thing that i assumed was the modification is on your blown up parts picture item 8KO-941-745 and is like a rubber boot that connects to a tube on the car as you offer up the headlight when you fit them. It is on the inner-lower part off the unit.
    Dunk
  9. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    Dec 2008
    Are you referring to part 26 in the picture? the breather hose? I think taht part is still the same...
  10. Re: Xenon Headlights - Have the replacement headlamp units cured the condensation / staining issues ?
    May 2008
    Yorkshire
    Quote Originally Posted by Red 2 View Post
    Same here. No problems to date.
    2020 B9 A4 Avant Black Edition S Tronic
    2016 FL C7 A6 Avant Ultra Black Edition S Tronic | 2015 FL C7 A6 Avant Ultra Black Edition - S Tronic
    2012 B7 A4 Avant SLine |2008 B7 A4 Avant Sline | 2008 VW Golf PD150 GTI | 2007 VW Golf PD150 GTI
    2004 B6 A4 Avant Sport | 2000 A3 1.8T Sport | 1983 VW Golf GTX
  1. Question Can Xenon headlights be swapped in with halogen wiring loom?
    By DavidA4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-01-2012, 12:37 PM
  2. Passat B5 Xenon Headlights
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2010, 01:51 AM
  3. I've got Xenon headlights, now what?...
    By x_cessive in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 10:08 PM
  4. Xenon Headlights to none OEM Xenon Cabriolet
    By brooksyboy in forum Chat - Anything with wheels
    Last Post: 12-10-2009, 11:48 PM
  5. Replacement / Fix Condensation S6 Xenon headlight
    By Damos6avant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-06-2009, 09:16 PM
