Thread: Power Steering failure
  1. Power Steering failure
    Feb 2009
    Hi all,
    I own an A3 2.0TDI and a couple of months back I have acquired a red steering wheel fault light on the display. It started off amber then red and came on intermittently. For the last few days this is now on permanently.
    I took it to a friend who ran a scan on it and it came up with a few faults.
    Address 44: Steering Assist
    Cannot be reached
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001047300188
    Coding: 3D0F0B4A070101
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 91
    Reset counter: 156
    Mileage: 138921 km
    Time Indication: 0
    Date: 2010.02.16
    Time: 18:50:34
    Any pointers as to why there is no communication would be greatly appreciated.
    Regards
    Jim
  2. Re: Power Steering failure
    Check fuse 2 on the fuse holder on the battery and fuse 3 on the fuse holder on the side of the dash panel
  3. Re: Power Steering failure
    Feb 2009
    Hi Kenney
    Thanks for the quick reply. I've checked both of those fuses and both are ok.
  4. Re: Power Steering failure
    it's not looking good for you matey only one thing left to check and that is the connector and wiring on the steering box
  1. Replies: 38
    Last Post: 08-06-2021, 07:43 AM
  2. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  3. power steering on a Golf MK1
    By NicholasP in forum Golf MK1 - 1974 -1984
    Last Post: 10-08-2007, 07:50 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
