Thread: Break Fluid
  1. Break Fluid
    Jul 2009
    Belgium
    hi every body i need some advice before to change my break fluid on my a4 1.9 tdi what should i not do and what is the best way to do it any advice is welcome thanks
  2. Re: Break Fluid
    May 2008
    Finland
    You'll need a friend for this:
    1.) Jack up the rear driver's side (for you RHD folk) wheel and remove the wheel, find the bleed screw on the caliber and attach a lenght of clear plastic hose to it or use a brake bleeding kit
    2.) Open the brake fluid tank lid
    3.) Open the bleed screw and have a friend press down on the brake pedal. Close the bleed screw BEFORE LIFTING THE BRAKE PEDAL! Repeat
    4.) Monitor the fluid level in the tank and DO NOT LET IT GET EMPTY!
    5.) Repeat untill only clear new fluid is coming out of the bleed screw
    If you don't let the brake fluid tank get empty, you'll be fine. However, if you do, you'll need a pressure bleeder at 2bar to bleed the ESP and ABS systems.
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  3. Re: Break Fluid
    Cork
    And what with the other 3 wheels ? not worth doing?
  4. Re: Break Fluid
    Pembrokeshire
    22 Post(s)
    then repeat the process on the other 3 wheels. bleed about 1 litre through the system, about 1/4 litre per wheel.
  5. Re: Break Fluid
    Jul 2009
    Belgium
    thanks to all .its clear
  6. Re: Break Fluid
    Mar 2007
    Lancashire
    Or get an easy bleed kit and then you don't need someone to pump the pedal and risk going to low with the pedal. I have a gunsen easy bleed kit. well worth it.
    Also you are best bleeding the brakes in the correct order! manual should advise.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  1. Sharan Auto Box Issues.
    By delphius1 in forum Touran - Sharan - Caravelle
    Last Post: 31-01-2011, 06:23 PM
  2. Please Help Front left wheel break not working (no hydrolic fluid pumped to this wheel)
    By wanla1 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-01-2010, 11:34 PM
  3. I put break fluid in power steering resevoir
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-09-2009, 09:05 PM
  4. Break fluid
    By v6dub in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2008, 06:28 PM
  5. Power steering fluid leak
    By tBoris in forum Audi A4 - Archive Topics
    Last Post: 19-09-2006, 10:12 AM
