Thread: no brakes
  1. no brakes
    Sep 2008
    hi guys. a good friend of mines drives a 2001 model passat and the other day his brakes completely stopped working. He had previously been changing the front discs and pads and took the car for a spin. Everything was ok untill the next day when the brakes stopped working, only the handbrake works and there is no light present on the dash. This has confused us both.
  2. Re: no brakes
    Pembrokeshire
    22 Post(s)
    what do you mean by stopped working. pedal to the floor and no brakes, or very hard pedal and some brakes, or pedal wont budge and no brakes ?
  3. Re: no brakes
    Sep 2008
    thanx for replying zolaf. Found the servo to be faulty. Very small hole in it. If this is the fault, would this disrupt the flow of brake fluid to the calipers.
  4. Re: no brakes
    Norfolk
    If the servo is not air tight (vacuum tight) it won't work. The brake pedal will need much much more push than normal, so it will feel rock hard and feel like the brakes are not working.
  1. Ghost in the machine
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-01-2010, 07:23 PM
  2. Help... Brakes & MOT (I feel like crying)
    By jimbo73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2009, 11:21 PM
  3. Front brakes stuck on.
    By Lanks in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2009, 07:33 PM
  4. brakes stopped working coming upto the lights!
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2009, 10:02 AM
  5. Passat TDI locking brakes
    By Cathyscar in forum Archive posts
    Last Post: 23-04-2007, 11:41 PM
