Thread: Exhaust mission warning light.
Results 1 to 8 of 8
  1. Exhaust mission warning light.
    Apr 2007
    I posted some time ago about the same subject but the problem still persists on my daughters 2006 1.4S Golf. The exhaust emission warning light keeps coming on albeit intermittently. A local mechanic checked it with his diagnostics computer and said that it was the fan sensor at fault. The fan is on most of the time and the car is using excessive fuel. The mechanic spoke to the local VW dealer who informed him that 3 sensors control the fan and it was a case of replacing each one till the faulty one has been located. One has been replaced but the warning light keeps coming on. The sensor that was replaced cost £28 plus fitting together with the cost of it being diagnosed and it's still faulty. Can anyone confirm this about the 3 sensors and can they be bought anywhere else, aftermarket ones from other than a VW dealer? If I were to replace the other 2 myself would the fault light need resetting? Apologies for all the questions. Thanks in anticipation.
  2. Re: Exhaust mission warning light.
    Jan 2009
    towcester northants
    if the fan runs all the time its usually the fan itself
  3. Re: Exhaust mission warning light.
    Apr 2007
    No I said the fan was on most of the time.
  4. Re: Exhaust mission warning light.
    Jan 2009
    towcester northants
    the fan control unit in the fan itself play up and have been modified
    the fan can run when cold and can run when ignition turned off for a good length of time
    if your fault is with the fan control unit it will most probably be the fan itself
    IVE CHANGED SEVERAL FOR THIS FAULT!
  5. Re: Exhaust mission warning light.
    Feb 2010
    London
    Quote Originally Posted by ronnyb View Post
    I had a problem with the exhaust warning light (as VW calls it) also called emmisions warning light. I took it to a mechanic who told me one of my pistons was misfiring. If the car jerks at neutral/gear one until gas is applied then it maybe the same problem. The mechanic then wittled it down to one of the three problems.
    It can be either the Injectors, spark plugs or coil pack.
    In my case it was the coil pack on cylinder 4 which misfired. Eventually I got an OEM coil pack from VW for £32 and it works perfectly fine now.
    However get a diagnostic done and fined out the VAG code means and take it to a decent mechanic to deal with it.
    I hope this helps.
  6. Re: Exhaust mission warning light.
    Apr 2007
    Thanks all, presumably towcestervag, that means a complete new fan unit?
  7. Re: Exhaust mission warning light.
    Jan 2009
    towcester northants
    yes it is the small fan that plays up
    ive not changed a sensor for the fan running unless it wasnt working
    did your mechanic have a fault code for the problem?
  8. Re: Exhaust mission warning light.
    Apr 2007
    The printout reads, 18080 P1672 Radiator open fan activation circuit 1: open or short to ground.
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Golf MK6 TDI DPF warning light !
    By moe360 in forum Golf MK6 - 2009 - 2013
    Last Post: 06-02-2010, 12:07 AM
  3. Exhaust warning light
    By ross130495 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-12-2009, 01:09 AM
  4. v6 4motion Exhaust warning light
    By stevie-g- in forum Archive posts
    Last Post: 22-10-2007, 11:04 PM
  5. Engine Warning Light 2001 Passat
    By derekdublin in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:10 PM
