Thread: New Passat - bumper Removal - help!
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
  1. Re: New Passat - bumper Removal - help!
    #31
    Feb 2009
    ok, so indeed you were right. there are some rubber strips holding the sensor on the bumper.
    i removed one just to see how it goes. but now, my feeling is that if you remove it, the rubber strip will be a bit torn and when/if you put it back, it will not fit perfectly.
    am i correct?
  2. Re: New Passat - bumper Removal - help!
    #32
    May 2007
    17 Post(s)
    I've never had a problem refitting the removed sensors. They shouldn't be that tight in the holes to tear the rubber. If anything, I think that type of sensor is a bit loose in the holes. The Cobra sensors are a much better fit but they are a bit harder to remove.
    Jim.
  3. Re: New Passat - bumper Removal - help!
    #33
    slimgeo Guest
    Quote Originally Posted by Flash2 View Post
    These figures come from VW, so don't blame me if you find a chunk of metal behind any holes you drill. If in doubt, remove the bumper and check for yourself.
    Regards - Jim.
    Can anyone verify that there are no chunks of metal behind the dimensions listed for the saloon
  4. Re: New Passat - bumper Removal - help!
    #34
    Feb 2009
    Cork,Ireland
    I removed the bumper to fit mine. Its really not that much effort for the peace of mind. You can also cable tie the sensor cables out of harms way.
    Just one regret for me. I fitted my dolphin sensors in the pre-marked positions that you will see if you remove the bumper. However because this section of bumper above the chrome strip is not vertical, the sensors will not detect anything below 500mm. If I was doing it again I would fit them below the chrome strip.
  5. Re: New Passat - bumper Removal - help!
    #35
    May 2007
    17 Post(s)
    No, no chunks behind the holes if you use those dimensions...unless VW made a mess of building your car.
    You'll be fine. I've fitted loads of them and never had to get the angle grinder out once.
    Cheers.
    Jim.
  1. rear bumper removal
    By bigb1970 in forum Passat - Archive Topics
    Last Post: 08-11-2007, 10:23 AM
  2. Bumper Removal
    By RonJon85 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-05-2007, 06:46 PM
  3. 2001 Passat Steering Wheel Removal
    By chrisball666 in forum Passat - Archive Topics
    Last Post: 10-12-2006, 12:04 PM
  4. VW Bora Rear Bumper Removal.
    By m_heathcote in forum Bora - 1998 - 2005
    Last Post: 20-06-2006, 01:55 PM
