Thread: Golf MKIV Shaking
  1. Golf MKIV Shaking
    sunilnc Guest
    I've got a 1.4 16V MK4 golf. When the cars in neutral it shakes a lot and often the Engine Light begins to blink every now and again. Anyone had this problem before and know a way to fix it? My friend said the throttle probably needs cleaning. So might give that a go, but anyone else have any ideas?
    Thanks in advance.
    Shipz Guest
    Hi mate..
    New to this site so not sure how or if this is going to come out alright...but does the car drive alright?
    I did have a problem with my Bora recently where the whole car was shaking while staionary plus when driving...and the warning light also came on...
    At the end it was a coil pack which was misfirin, so i had to change that.
    It has something to do with the ignition i think,
    Hope this info helps; and hopefully its nothing too serious!
    Shipz
    Dec 2006
    if it was a newer model i would say a coil pack issue..
    But as the lump is older.. could be a MAf issue.. or even a simple spark plug issue..
    i would first replace the spark plugs and take it from there..
    Let us know how you get on
    RicKT
    sunilnc Guest
    Quote Originally Posted by Shipz View Post
    Hi mate..
    Shipz
    Thanks Ships and RickT for the info.
    Ships...it drives alright, just that when its in stationary it shakes and the warning light does tend to come on now and again.
    The coil pack misfiring...can this be easily changed and how do I go about doing it? Any help would be appreciated.
    Shipz Guest
    Its not too difficult nor expensive..
    I've got the 1.6 16v, and that has a coil pack for each cylinder...
    Had to put the car through a diagnostic machine to find out which one was misfirin, but if your car drives ok, then it must be something else...FYI a caoil pack is located in the engine under the black air thing on top of the engine, just need to undo a few nuts then the harness adapter and it will pop staight out and they're only around £27 or so from the main dealer (and only original genuine parts fit)
    not the best with car stuff, so i can't really suggest what your prob may be!
    If you know a mechanic, best thing may be to put it through the computer to see whats wrong
  1. Golf GTI MkIV Cambelt Change
    By simpsonskywalker in forum Chat - Completely Off Topic
    Last Post: 02-01-2008, 10:16 PM
  2. AC Problems - MkIV Golf tdI
    By Longmover in forum Golf MK4 - 1999 - 2004
    Last Post: 11-04-2007, 01:31 PM
  3. RS6 wheels on a golf mkiv
    Last Post: 19-03-2007, 07:02 PM
  4. MkIV Golf swimming pool
    By bgvw in forum Golf MK4 - 1999 - 2004
    Last Post: 14-02-2007, 06:57 PM
  5. Golf MkIV leaking
    Last Post: 14-02-2007, 11:15 AM
