Thread: Indicator problem - not the usual.
Results 1 to 10 of 11
  1. Question Indicator problem - not the usual.
    Feb 2010
    Oxford
    First of all, I've tried fitting a brand new hazard light switch/relay - no cure.
    PROBLEM - When the indicators or hazards are not being used, a relay in the hazard light switch goes crazy, clicking, chattering and buzzing at random.
    If I turn the indicators or hazards on, they work fine and I just get the normal click, click, click with the correct lights.
    I think it may be a <12V 'leak' to the relay due to a bad earth or other fault, but I am not sure.
    Can anyone suggest likely place to look or ways to diagnose this problem?
  2. Re: Indicator problem - not the usual.
    Do you have a towbar fitted with the trailer contact?
  3. Re: Indicator problem - not the usual.
    Feb 2010
    Oxford
    Quote Originally Posted by kenney View Post
    Good point, there WAS, but I removed it and all the associated electrics - no change
  4. Re: Indicator problem - not the usual.
    Disconnect the connector to the indicator stalk an see it it stops. Regards Peter
  5. Re: Indicator problem - not the usual.
    Long shot, Check under the passenger side front footwell, ideally under the carpet, for any sign of water. There is a feed from the CCM to the hazards to turn them on if the airbags trigger. Regards Peter
  6. Re: Indicator problem - not the usual.
    Feb 2010
    Oxford
    Thanks for the idea, but foot-well is dry.
    Any others?
  7. Re: Indicator problem - not the usual.
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I have the same problem which has been a pain for the last 6 months. I my case the problem varies from day to day from a slight crackle to lots more and continuing after I have returned te indicator to the neutral position. I today took the stering wheel off and played with the wires in the indicator cruise switch but did not notice any difference. I might need a new indicator switch, but would like to be sure.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  8. Re: Indicator problem - not the usual.
    Feb 2010
    Oxford
    I have had a similar thought and just ordered a new indicator/cruise stalk from Ebay - I'll let you know if it cures it...
  9. Re: Indicator problem - not the usual.
    Feb 2010
    Oxford
    Dug out my multi-meter and got the following:
    From the cigarette lighter (-) I got the following reading from the bare hazard switch socket pins:
    1 = No conductor
    2 = +12.57
    3 = -0.003
    4 = +12.54
    5 = -0.003
    6 = +0.116
    7 = -0.003
    8 = +7.65
    9 = +0.013
    10 = +12.53
    So, pins 8 and maybe 6 are looking a bit suspect....
    Crash signal, airbags and central locking?
    Tried disconnecting 8 - no change!
    Tried disconnecting 6 - no change!
    What little hope I have left is pinned on the new indicator stalk solving this......
  10. Re: Indicator problem - not the usual.
    Pin 6 pulses when you lock the car to flash the indicators. Pin 8 if from the Airbag controller and appears a bit odd. Can you connect the relay/flasher unit and measure pin 8 in situ. Regards Peter
  1. Please Help ABK - The usual suspects!
    By 100ABK in forum 80 - 90
    Last Post: 13-02-2010, 07:10 PM
  2. Please Help Rear washers not working - NOT the usual problem...
    By MrShades in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2010, 01:48 PM
  3. A6 Windscreen Wiper Problems (but not the usual)
    By 1299cc in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2009, 03:20 PM
  4. Odd immobiliser question... (not the usual one)
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2008, 10:24 PM
