Thread: cold start mis fire
Results 1 to 10 of 10
  1. cold start mis fire
    May 2009
    wirral
    any ideas on this--car idles lumpy then settles after a few seconds vw passat sport 2.0 tdi 140 06
  2. Re: cold start mis fire
    Norfolk
    Get the glowplugs checked just incase you have a dud. Do you see any sign of unburnt fuel. It looks abit like steam but smells of fuel.
  3. Re: cold start mis fire
    May 2009
    wirral
    thanks martin1810 checked that today no unburnt fuel and no steam(was quite cold so did see condensed exhaust fumes) only seems to play up when its first started cold and it never seemed to effect it during summer. pulls like a train still! not had a good dose of shell v power for a while so may try that and if no change, a trip to my friendly vw specialist is in order.
  4. Re: cold start mis fire
    Jan 2010
    Wombourne, UK
    I experienced a similar problem in cold weather, but found that if I waited until the glow plug light went out before I started the car then it started and ran smoothly. I tried this after realising that my wife’s car would pause starting until the glow plug light went out!
  5. Re: cold start mis fire
    May 2009
    wirral
    ah thanks for that one muggysnr car starts up same even after letting glowplug light go out-must be just a winter thing but martin 1810 advice is on my mind at the moment- never had to have glow plugs replaced on any of my cars and my car has done just short of 60000m
  6. Re: cold start mis fire
    131 Post(s)
    1977 Post(s)
    Is it using water?
    This can be a symptom on an injector on the way out, when they do eventually fail, the car just stops unlike the earlier PD’s when they dropped onto 33 cylinders. I did a 2007 Passat 3C like this earlier this week, it just stopped dead in the road, it was just one failed injector but the ECU shut the engine down.
  7. Re: cold start mis fire
    May 2009
    wirral
    doesnt seem to have lost any water, Crasher. How are the plugs linked to cooling system?
  8. Re: cold start mis fire
    131 Post(s)
    1977 Post(s)
    Plugs? The glow plugs can come up as faulty on scan and if it is suffering from head porosity issues, the glow plug on number 1 often comes up as faulty
  9. Re: cold start mis fire
    May 2009
    wirral
    ah right -no fault codes or ecu warnings and hope to rule out porosity issues as water level is ok and hasnt changed since last i looked at it over a month ago. any idea what going rate for checking and replacement for glowplugs at main dealer and independant-assume this is a garage job?
  10. Re: cold start mis fire
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by muggysnr View Post
    Always wait for the glow plug light to go out, that's what it's there for. Only takes a second or two - I usually put my seatbelt on.
    1996 Laguna 2.2D
    1977 MGB roadster
  1. GOLF GT TDI (150) 2002 Intermittent Poor Start
    By JamesVW in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2010, 04:53 PM
  2. Yet another white smoke on cold start - but maybe fixed?
    By richard_gomm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2009, 04:35 PM
  3. Why wont it start?? Pls help!! (Golf mk3)
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2008, 09:22 PM
  4. AEH cold start problem
    By babariba in forum Golf MK4 - 1999 - 2004
    Last Post: 01-03-2008, 09:20 PM
  5. audi coupe cold start ???
    By sox in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-01-2008, 08:53 PM
